Help, please! I am looking for possibilities to fix my tv KV36XBR400.
It has no pic - screen is dead. The tube is not energizing, but the sound is OK.
I played mp3 files sourced from dvd player in time when TV screen shut down. Still, I am able to watch TV, play DVDs, etcs, ONLY if I am sending video signal out to other display (projector).
Hope, it is fixable, look like something is prevent the tv tube from been energized.
Please advise what I can do to fix it by myself - it is damn heavy stuff to lift it up/transport.
Sinserelly, Mikhail.
  • mikhail39 Dec 26, 2007
    SONY 36" Vega Trinitron KV-36XBR400 6 years old.
    In time when I shut TV down, the standby light turn on red/orange with no blinks.
    When Tv turn on by pushing TV Power button, then the red/orange light blinks 5-7 times.
  • 1,113 Answers
What is the model/make of this heavy Tv? I power light indicating any error codes?
Posted on Dec 25, 2007
  • Soulvisitor
    Soulvisitor Dec 26, 2007
    The blinks are the key they indicate area of problem
    KV32HS420, KV32XBR400, KV32XBR450, KV36HS420, KV36XBR400, KV36XBR450 D board circuit failures are common.
    Sony have a exchange board program where you send them a faulty board and they will send you a replacement board they charge $325.00 per board.
    Display of Standby/Timer LED Flash Count
    *One flash count is not used for self-diagnostic.
    2 LED flashes
    (+B overcurrent (OCP))
    • H.OUT (Q5030) is shorted. (D board)
    • +B PWM (Q5003) is shorted. (D board)
    • IC9001,9002, 9003 is shorted.(C board)
    - Power does not come on.
    - Load on power line is shorted.
    3 LED flashes (+B overvoltage (OVP))
    • IC6505 is faulty. (D Board)
    - Has entered standby mode.
    4 LED Flashes (Vertical deflection stopped)
    • +/-15V is not supplied.(D board)
    • IC 5004 is faulty. (D board)
    - Has entered standby state after horizontal raster.
    - Vertical deflection pulse is stopped.
    - Power line is shorted or power supply is stopped.
    5 LED flashes (White balance failure (not balanced))
    • Video OUT (IC9001-9003) is faulty. (C board)
    • CRT Drive (IC201) is faulty.(A Board)
    • G2 is improperly adjusted.
    - No raster is generated.
    - CRT cathode current detection reference pulse output is small
    6 LED Flashes (LOW B OCP/OVP (overcurrent/overvoltage))
    • +5 line is overloaded.(A, B Boards)
    • +5 line is shorted.(A, B Boards)
    • IC6007 is faulty. (A Board)
    - No picture
    7 LED flashes (H-Stop)
    - No picture
    info from web below...
    When it comes to TV sets, the first thing to always remember is that if you have no electronic experience or training, there really are no user serviceable parts inside of the TV, as they're all solid state. You're going to need to know how to use a simple digital or analog multimeter, and you should also know how to solder and unsolder, as almost all parts in most TV sets are soldered in place on the printed circuit board.
    Know the Risks
    Before you begin, you must be aware of the safety issues concerning the Hi Voltage in a TV set. All TV sets that have a picture tube, including CRT rear-projection sets which have three picture tubes, will have a Hi Voltage transformer with a heavy red wire that connects to the picture tube with a suction cup. Under there is an average of 32,000 volts when the TV is powered on, and even when powered off can hold a large electrical charge. If it zaps or bites you, it can make a grown man cry, or even stop your heart! So, be warned that you should never stick a screwdriver under the Hi Voltage cap... even if it’s unplugged.
    If the cap has to be removed, take a clip lead and attach one end to the metal exposed strap that’s around the picture tube, and the other end to the screwdriver. Slide the screwdriver under the cap slowly, and without the metal blade of the screwdriver coming into contact with you. There should be a little pop if there’s any voltage left. Now, wait for a second or two and remove the screwdriver. Then, pinch the top of the cap perpendicular to the wire while pulling up on it. Never pull on the wire! With the cap off, clip the clip lead to the anode connection on the tube while the other end stays on the grounding strap. Also, never splice the Hi Voltage wire without using Hi Voltage putty on it and heat shrink tubing.
    Most sets nowadays have what’s referred to as a "hot chassis". It's called this because the part of the metal chassis around the power supply in some sets are 70 volts DC above ground and have voltage on them. So, never ground anything on a heat sink without first measuring the voltage by using the tuner shield for ground to see if there’s any voltage there.
    There are many larger capacitors inside of a set that will also hold a charge. Before unsoldering, jump out the capacitor with a 20 to 50 ohm resistor to discharge any voltage left in them. Also, never jump out any part to see if it works, as they are there for a reason.
    If these rules of safety are not followed to the “T”, you could cause serious injury to yourself, or even death.
    Troubleshooting a Dead TV
    So you have a dead TV set? There could be one, or a combination of many things that could cause a TV not to work or start up. It could be as simple as an AC fuse, a shorted thyristor caused by a power surge, or a defective component. Always remember that a fuse will very rarely blow all by itself for no reason, so NEVER replace a fuse and plug it in without following the instructions below.
    Fuses & Thyristors
    Manufacturers do not always use thyristors, and like I stated above, it will short out and blow the main fuse in case of a power surge coming through the AC line. If the fuse is blown black, replace the fuse only with the correct amperage rating, which commonly stated on a label around the fuse or etched on one its ends. Now, with the end of the plug out of the wall, measure the ends of the plug with an ohm meter or continuity checker. If it shows a dead short, take out the fuse and look for the thyristor. A thyristor is usually a small black square, right past the main AC fuse. Replace it. If there is no thyristor in your TV, keep the fuse out and continue troubleshooting.
    The Standby Power Supply
    The best place to start troubleshooting would be the standby power supply. If bad, there won't be any voltage for the remote or microprocessor circuit to work with. There could be what’s called a switch mode power supply, or one that uses a low voltage transformer. If the fuse was black and open, there's most likely a short in the set that has made the fuse blow.
    To stop any further damage to the set (just in case there is a short somewhere), would be to use a pigtail light bulb socket with a 100 watt light bulb in it. The light bulb will absorb the current that’s being drawn from the short in the set. Attach some clip leads to the end of the pigtail, and with the plug out of the wall, clip the pigtail wires across the blown fuse. Once connected, plug in the set. If the light bulb glows bright and then goes dim right away, there is likely no short in the set, or at leat it’s not a dead short.
    Now, measure a capacitor around the power supply area and see if you have voltage. No? You may have a burnt printed circuit trace or open power transformer. You can replace the fuse and see if you got lucky with only having a blown fuse. If the light bulb glowed bright and stayed bright, there’s a dead short in the set. Sometimes there’s a large, low value rectangle resistor called a current limiter located right after the fuse. This will sometimes open up instead of the fuse. If the resistor is open and the fuse is not, you can then install the light bulb across the resistor IF, and only if, the value of this current limiter is 20 ohms or less.
    The Main Power Supply
    The next step in troubleshooting would be to check the main power supply. First, check the bridge rectifiers. A bridge rectifier could be a combination of four silicon diodes or a square rectangle type package. Use the diode function on your multimeter and see if there’s a short across one of them, or perhaps between the pins of the rectifier block. If there’s no short there, measure across the main B+ filter capacitor, but make sure you discharge it as described earlier! If there’s a dead short there, take out the cap or disconnect one end to see if it’s shorted. If not, reinstall or resolder, then measure the transistors and diodes around the power supply area. If you don’t find a short with one of those components, go to the horizontal/sweep power supply circuit.
    The Horizontal Output Transistor & Flyback
    First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
    If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
    Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.
    Final Thoughts
    You will find the short in the board if you're persistent. Just remember, do not replace the fuse if the bulb stayed bright, as this could cause additional damage to the set. I have experienced a few occasions where lighting has hit a cable or electric line outside, and damaged every IC in the set.
    The fixes described here are general, common problems that occur when a television set goes dead. Remember that working inside of a television should never be taken lightly, and that safety should always come first.
    by Larry Dillon
I need a picture tube for my 50in.Sony t.v . I live in central MI. Need to know where & how , to buy & fix the pic.tube Thank You...
projection screens dont use tubes,a 50 inch tv tube will cost 1000 a new flat screen tv is alot cheaper,buy a flat screen hd ready tv
Apr 16, 2015 | Televison & Video
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
1996 mitsubishi 40" tv has a black screen and
no pic at all usiually means the the heater element in the picture tube it self is burned out. Also there could be a problem with the internal power supply that gives electricity to the heater element. These are all thing the cunsumer cant fix. You either need to trust ONLY a certified Mitsubishi TV repair man, or replace the TV.
I know it's not great news, but if this advice helps, please give me a good rating.
Jun 30, 2011 | Mitsubishi CS-40505 TV
HELP PLEASE! I just moved in a JVC I'Art tv that is around 30 inchs. Its a flat screen but not like any modern flat screens, its sliver and still has the big back. The TV's picture for some...
Hmm.. Sounds like the tube is on the way out, which will cost more to fix than a new TV might be.
Having said that, look in the set up menus of the TV (if possible) too see if there are any settings that have gone a bit strange. It's always worth a fiddle, because you can't do any more damage.
Jun 13, 2011 | Televison & Video
Sony KV-32FX68U problem, blinking power light
Please update this with the count of hte blinks. This is a diagnostic code that will indicate the problem circuit. From that we can tell you probable solutions and their costs.
Thanks,
Dan
Sep 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv turns on but no pic or sound
dear friend the picture tube in your t.v is damaged that's why
Aug 22, 2009 | LG 42LC2D 42 in. LCD HDTV
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
Bush 42" rear projection rp40tv sound but no pic
any help please thanks tv turns on no problem but can not see any thing on screen. code comes up cant use menu do you no the code
Dec 16, 2008 | Bush 5693D 24" TV
Wharfedale 37 inch lcd tv
sounds like screen control is set too high
Sep 02, 2007 | Televison & Video
Arcing around neck board
sounds like bad crt if you saw arc inside glass...no economical fix-replace the monitor
May 30, 2007 | Likom ViewMate LP995 (White) 19 in.CRT...
Televison & Video Logo
182 people viewed this question
Top Televison & Video Experts
