Olevia lcd and directv receiver conflict
My directv receiver works great with a Panasonic and JVC television in my house, but cannot find a signal when I connect it to an Olevia 232T through either HDMI or component connections. The DirecTV guys spent hours here replacing everything to no avail. The feeling is that my TV has a grounding or stray voltage issue from the TV to the receiver. Should the HDMI connection out of the TV have any voltage? I measured 3.3 volts on several pins and 4.6 on a couple.
SOURCE: Remote control codes
Thirty seven inch olevia direct tv remote code is 11610!
Posted on Jan 06, 2009
  • 3 Answers
Check here, it should work out for you - universal-remote-controls.blogspot.com
Posted on Mar 19, 2009
  • 45 Answers
SOURCE: I have an Olevia 542-B11
its hard to find a remote that will work an olevia , since this brand is new and alot of manf. that make universal remotes have not updated there system..
This company called Amergence Technology sells the Olevia Remote and will control any olevia television.
Contact them at 866-965-3842 (just ask to purchase a remote)
Posted on Jul 28, 2009
  • 45 Answers
SOURCE: hughes remote codes
The only model of remote that i heard that it has pre-program Olevia code in it.. is the RC-64 or RC-64RB usually these remotes are coming with the new HD boxes..
Direct TV
Remote Codes 506 or 127
Direct TV (Remote Model RC-64RB)
Remote Codes 11144, 11240, 11331, or 11610
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available… please call at 866-965-3842
  • 45 Answers
SOURCE: HELP Can't find manual or remote for 232T Olevia
This manual is for the 232V but its the same functions as the 232T
http://www.olevia.com/ecms.ashx/36cc6c74-60f9-4caf-b6f7-d05024d13e44/Products/232V_English_User_Manual.pdf
Also Olevia made a universal / Learning remote that will work with olevia and also with other device.. the company that is currently selling them are called Amergence Technology ( ph. 866-965-3842 )
Posted on Jul 30, 2009
Cannot pmy "Direct TV Satellite Remote, so I can control TV Sound
10178 or 11331 or 11610, depending on the model of your remote.
Sep 13, 2009 | Syntax LT26HVE 26 in. HD-Ready LCD...
I need the Olevia 427-S11 TV Remote Control Codes , please.
the remote control code for DirecTV with Olevia 242T or 237T (37' or 42') model is 11610. this code will power on/off and volume up/down the buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to olevia.com - accessories - remotes.
Jul 06, 2009 | Olevia LT32HVM 32 in. LCD Television
Hughes remote codes
Direct TV
Jun 02, 2009 | Syntax Olevia 226T 26 in. LCD Television
Program code for olevia 37 to direct tv remote
Mar 15, 2009 | Olevia LT37HVS 37 in. LCD HDTV
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
Olevia 32"lcd
All I did was switch out televisions and found that the DirecTV receiver was the problem.
Sep 13, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
DIrectv Sat internal box.
You can try eliminating whethor or not the receiver is actually the problem by moving it to another TV and seeing if it works on one that isn't having any problems. Or moving a working receiver onto the TV to see if it will pick up signal with a working receiver. If you don't have any receivers in your house working, then odds are something needs to be serviced outside your home, like the Dish and/or LNB.
Did DirecTV actually come out to the home and troubleshoot at the site? If not, they would have no way of knowing if it's the TV or Satellite that's causing the issue.
Aug 09, 2007 | RCA F38310 38" TV
Cannot use the direct tv remote to control the volume, on / off, etc.
In used 10463 for my Direct tv remote...it is an Emerson code. It worked on my 27inch Ilo, from Walmart. Good luck.
Mar 01, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
