Question about Sew D'Lite 11401 Mechanical Sewing Machine
How do i fix the under stich
Every time I sew the front of the material is sewed correctly but the back is tangled up. I lost my owners manuel so i have no clue what to do?
0 characters
1 Points
I bought this for my granddaughter. we just tried it for the first time and it doesn't sew. It works, looks like all is going well but does not stich.
Assuming that this is the first time you use a sewing machine I'd tell you that you don't have the thread properly looped. Read the book and insert both threads in it step by step. But if you are skilled at sewing, then the machine may be defective
May 07, 2016 | Sewing Machines
Having trouble with tension on my Husqvarna Viking E 20
Be sure to RAISE the presser foot BEFORE threading the upper thread. (Remove the upper thread and rethread from the beginning.) Upper thread malfunctions commonly occur if it is not threaded correctly or the thread is not seated in the tension disk properly.
Install a brand new needle if you haven't already done so.
If it continues, this information about bird nesting could be helpful:
Sewing Machine Thread Bunching Up Here Why
Why Do Get Bunched Up Thread Under My Fabric
8 Tips to Fix Birdnesting in Embroidery
Why Is the Thread Getting Tangled Up Under My Material When Use My Sewing...
Jan 22, 2016 | Husqvarna Sewing Machines
How can I stop my material sliding around when I am sewing?
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
How do I sew denim and heavy fabrics?
Why is my bobbin not winding evenly?
Why won't my machine pick up the bobbin thread?
Why is my machine skipping stitches?
Why is the thread looping/bunching under my fabric?
Why is the thread looping/bunching on top of my fabric?
Why doesn't my stitch pattern match what is on my machine?
How often should I oil my machine?
What types of thread should I use?
I can't see the take-up lever? t
May 16, 2015 | Sewing Machines
The material is'nt moving when it stiches
check the feed dogs they could be stuck
Oct 05, 2014 | Sewing Machines
Lost quick fix owners manuel
Contact the manufacturer on line. You should be able to download a new manual.
Jan 18, 2014 | Singer 5050 Mechanical Sewing Machine
Start sewing about 3 stiches in and thread for bobbin gets tangled up
hi, normally that problem is associated with the top tension being too loose .. Timing could also being playing a part here ...
Dec 30, 2013 | Michley Lil Sew Mechanical Sewing Machine
My machine is a designer 2 but I encounterd a problem with my stich getting all tangled. tryed to clean the bobbin case and under, stich is still tangling bad.
Be absolutely sure that the machine is threaded correctly, with the upper thread clicked into the tension discs (the presser foot MUST be raised when you thread so the tensions discs are open to receive the thread) and bobbin thread clicked into the bobbin tension slot. Change the needle - a bent or blunt needle can cause tangles. Hold onto the thread tails for two or three stitches when you first start sewing to avoid them being drawn down under the fabric and making a mess.
Dec 19, 2010 | Husqvarna Designer I
Hi I thread the machine as normal and begin to sew, the material moves forward under the foot but stiches are not forming
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
Sep 02, 2009 | Sewing Machines
Lost manual
  • I'd satisfied to sew cotton/polyester than silk fabric, match more commonly use needle for cotton is no. 14 and stich no.3
Mar 08, 2009 | Sewing Machines
Sewing machine not making stiches
At first, my machine was getting all tangled under the fabric and then would stop working because it was tangled in the bobbin area. Now the bobbin area is staying clear but there are no stiches being made. I have no idea what to do.
Sep 07, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sew D'Lite 11401 Mechanical Sewing Machine Logo
Top Sew D'Lite Sewing Machines Experts
Mike Cairns
Mike Cairns
Are you a Sew D'Lite Sewing Machine Expert? Answer questions, earn points and help others
