Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Cf card hi, i had about 150 photos in my camera, i accidentally went to "format cf card" and pressed ok. i now have no idea how to get them photos back. does anybody have a clue how as i am lost.
  • Canon Master
  • 4,738 Answers
It's no problem at all to get them back. Please see this post for several free software that you can download. You'll need a card reader to use with them though:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
Posted on Dec 26, 2007
Formatted photo's how to recover them
You can recover deleted photos after accidentally format the CF card with asoftech photo recovery program. download the free trial from
http://www.asoftech.com/apr/
Aug 22, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
I took my CF card out to get photos, went to put it back in and the screen read "There is a problem with CF card. Replace the CF card." I didn't think there was a problem with the card. But I replaced...
Your CF pins in the camera are most likely bent/broken. This is a very common problem. Most repair shops will charge $150-$200 to repair this.
Hope this helps.
Wes
Sep 10, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Canon eos 400d. card empty but cf light flashes red
Hi! Rachel, Mark here see if i can help.
Try different cf card see if it works.
Next if that worked or not take cf card place in computer & format card. Retry in camera.
Hope that fixed ya if not comment back me happy to assist you further. Good Luck! please rate.
Mar 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Feb 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 350d not turning on/screen not working/
Does the camera work properly with the CF card removed? If it does than the CF card is the problem. Try formatting the card with the camera or getting a new one.
Feb 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lost all photos
It's no problem at all to get them back. Please see this post for several free software that you can download. You'll need to use a card reader with these programs though:
After you've recovered your photos, consider formatting the card IN YOUR CAMERA. This should help prevent such episodes from happening again. This will also erase the card, so make sure that you've recovered the photos first.
Press menu, then select the tools menu. Scroll down to the selection showing the capacity of your card and select it. Follow the on-screen prompts for a "Low-Level" format.
Jan 11, 2009 | Canon PowerShot SD600 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
No CF card
The camera body has a tiny switch marked "CF" in one position and Sony's "memory stick" symbol in the other. Apparently I accidentally reset the switch from "memory stick" to "CF" while slipping the camera body into (or out of) its carrying-case. Once I had set this switch from "CF" back to the "memory stick" position, everything worked fine. Solution:  read the user's manual more carefully next time!!
May 08, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Scandisk curropt
You'll need a CF reader/adaptor for your computer, and software such as this
http://www.softwarepatch.com/software/smartrecovery.html
Just type "recover CF card data" and you'll find a host of downloads.
Oct 18, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
