Question about RCA TruFlat 27F520T 27" TV
My RCA F32650 won't turn on and green power light just blinks.
My TV worked fine now won't turn on either with the remote or at the panel. I left unplugged for several weeks and still nothing. Do the blinks diagnose the problem?
  • 1 more comment
  • Don60115 Feb 05, 2008
    MARR where should I check for cold solder? I assume cold means broken?
  • creepndeth Feb 05, 2008
    I have a 27" RCA True Flat. Lately it shuts on and off by itself. It starts switching channels in order like it is autoscanning. The sleep timer is off. I have an APC UPS 500 power back-up and it is attached to a Monster Cable Phase I power strip to eliminate outside electrical interference.
    I switched from the power strip to the APC to see if it was the strip. It started powering on and off and switching channels attached only to the APC as well. This is highly annoying at 4am in the dead of night and the demon decides to turn on and scare the be-jeezes out of us.
    Suggestions PLEASE!
  • Anonymous Sep 08, 2008
    I have a RCA F36650 that is experiencing the same problem. When I try to turn it on by the remote or by the burrons on the TV, the power light blinks three times then stops.
  • 49 Answers
Yeah the blinks will tell u the culprit..basically cold solder,or bad vertical ic.but u need prof tech to help u fix that..hope this help..yhanks
Posted on Feb 05, 2008
  • marcial  nasi
    marcial nasi Feb 05, 2008
    vertical/horizontal section...visually check for loose connected component..take an extra care..
Phillips 32" HDTV power light blinks green but wont turn on
the problem in the main power supply it depends of the kind of faillure but normaly to repair it not very expensive
good luck
Aug 23, 2009 | RCA F32650 32" TV
Tv powers on but light just blinks and no picture or volume
A blinking power light would indicate a problem on the chassis board located inside the tv. Possibly a failed flyback or other electronic component. Its not cost effective to repair when you can invest in new tv for the same cost as repairing the defective tv. I should also mentioned the danger of dyi troubleshooting of the components inside the tv. I do not recommend unless you are familiar with properly discharging the tube to avoid electrical shock.
Jul 25, 2009 | RCA F32650 32" TV
Same thing happened to me
Well, no sound no picture = power supply unit
Sound no picture= flyback
picture no sound =tuner/audio logic
You get my drift?
You power supply is bad you replace it you got another new TV, with this digital conversion hitting I would rather advise you to get a nice flat panel and donate that one to Goodwill
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 13, 2009 | RCA F32650 32" TV
RCA TV GEMSTAR GUIDE PLUS GOLD
what is this TV's modle #?
Aug 24, 2008 | RCA F32650 32" TV
Rca Television
I think that both of you have faults on the power supply of the tv. If you are able to check this yourself start with the diodes and resistors if not then find a competant technician. Hope this helps.
Aug 19, 2008 | RCA F32650 32" TV
Tv wont turn on
The green light indicates that it is getting power from the outlet ok.
The clicking is the power relay trying to turn it on but there is an internal fault forcing it to shutdown. You either have a power supply problem, horizontal output transistor (HOT) is shorted or a bad flyback transformer. In any case it can most likely be repaired by a qualified technitian. If it is the flyback it may be expensive.
Mar 10, 2008 | RCA F32650 32" TV
Bad RCA 32 Tube TV
Bad IHVT ( HV transformer ) part # 257805 or ASTI 2078
......................................................T.
Dec 11, 2007 | RCA F32650 32" TV
Hellp
Bad IHVT ( HV transformer) part # 257805 or ASTI 2078....T.
Dec 02, 2007 | RCA F32650 32" TV
Not turning on
Replace IHVT aka flyback xformer. part #257805 or ASti 2078.
Oct 05, 2007 | RCA F32650 32" TV
F32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
RCA TruFlat  27F520T 27" TV Logo
193 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
