Question about Pioneer DEH-P44 CD Player
Car radio removal
Hey there, i have just got a new head deck for my 1998 mitsubishi carisma but i cannot work out how to take out the stock radio. can you please help.
  • 162 Answers
SOURCE: Ok, so I have a 95 nissan maxima se and it has the
Your best bet is to go to a good stereo store that can get you a wiring harness adapter that will plug into your car and be color coded to wire up to your aftermarket radio.
It will save you a lot of time and trouble.
Posted on Feb 04, 2011
0 characters
1 Points
When i turn the head unit up to about 10 it sounds good but then it gets all distorted like my speakers are blown but when i pou the stock deck in the system freaken rocks whats the deal with that
it sound like a wire problem you brobably would not hear the distortion with the stock deck because the more power the less distortion there is.
Oct 25, 2011 | JVC KD-PDR30 CD Player
Ok, so I have a 95 nissan maxima se and it has the stock radio with the tape player so I took all that out , now im about to install the new deck in but I noticed the wirers dont hook up with the stock...
Feb 04, 2011 | Pioneer DEH-1300 CD Player
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
After i installed an after market deck on my 2001 chevy suburban my dash lights went out what can be the problem
I would put things back to stock and see if they now work. If they dont you may of shorted out a solder joint and ruined the cluster which would have to be replaced as a whole. If after you get it bact to stock and everything works I would be hooking up to a different power source. Also its always a good Idea to run an extra ground wire from engine to body when you add a more steroo system or accessories. This prevents electrolisis in the radiator which could eat thru the heater core or radiator.
Sep 02, 2009 | Alpine 50W x 4 Apple iPod /Satellite...
I am replacing the stock radio in my 2001 dodge ram with a JVC deck. The JVC deck is smaller in size. What is the best way to install the new deck so that it is tight in place and does not vibrate while...
There are retro- fit adapter plates and housings that will match your new radio head with the original opening. Either go on line or go to your local electronics store that sells auto audio equipment and ask for such an adapter for your vehicle.
Jun 21, 2009 | Kenwood KDC-MP228 CD Player
Get no sound from rear speakers WITH ipod
I have exactly the same problem - don't work with CDs either, just radio. Just installed the deck yesterday. Help would be appreciated. Have been through the manual front-to-back.
Aug 09, 2008 | Kenwood 50W x 4 Apple iPod -Ready MOSFET...
Car stereo and car remote not working
Definitely check all the fuses. Even the ones under the hood.
May 29, 2008 | Alpine CDA-9856 CD Player
Extending the Antenna wire to reach new deck
If it is a Chevy then the antenna wire will not fit in the first place. best buy sells an adapter that ill extend that wire and make it the right size. The wire is like 7 to 10 dollars.
Apr 14, 2008 | Kenwood KDC-MP235 CD Player
Audio Output problems
Currently you have the blue wire from your Kenwood head unit connected to the blue wire in the Chrysler wire harness adapter. You need to disconnect this wire, and reconnect it to the blue/white wire coming from your Kenwood head unit instead. You probably already have the remote wire from your subwoofer amp connected there; both wires need to be attached to the blue/white Kenwood remote output. Your LHS is equipped with a factory amp. The blue wire in the Chrysler harness activates the amplifier, but it's connected to your Kenwood's power antenna activation output; therefore it's only being turned on when the tuner is selected.
May 30, 2007 | Kenwood KDC-MP828 CD Player
Pioneer DEH-P44 CD Player Logo
222 people viewed this question
Top Pioneer Car Audio Receivers Experts
xxxxxx xxx
Are you a Pioneer Car Audio Receiver Expert? Answer questions, earn points and help others
