Question about Franklin MWD-1490 Dictionary / Translator
Flashing "Key Has No Effect"
Tried to turn on item for the first time and it flashes "Key Has No Effect"
Any idea's?
One of the keys is stuck, causing it to flash such a message.
Posted on May 21, 2008
Batteries
My GE Quiet Power 1 is constantly beeping when you press Normal wash, and then just flashing when you press Start/Reset.
Try cutting power to it at breaker box and see if electronics will reset. If not, sounds like a control board problem
Nov 11, 2017 | GE Dishwashers
Light wont stop flashing
Light flasher will not stop flashing.
Jan 13, 2014 | RCA Televison & Video
Electrolux ewf1074- cycle time flashing and beeping and not running cycle
Consult the manual first, if there is no troubleshooting , contact your dealer (thinking about the warranty term)
Dec 02, 2017 | Electrolux Washing Machines
03 grand am 3.4l no crank at all. All the light on dash work good fuel pressure starter spins and engine starts and then stalls when jumping the starter directly installed new pass lock switch and...
If the Passlock switch has been replaced, the computer has to "learn" the new Passlock code. You will need to hook up a battery charger to perform the learning process. (It takes about 30 minutes with the key in the "ON" position and it will run the battery down.)
Step 1:
Turn the key to the "START" position and release to the "RUN" position. The "SECURITY" light will be flashing. After about 10 minutes, the light will stop flashing.
Step 2:
Turn the key "OFF" then back to the "RUN" position. (Do NOT try to crank it yet) The light will start flashing again. Wait about 10 minutes for it to stop flashing.
Step 3:
Turn the key "OFF" and back to "RUN" one last time. The light will be flashing again. This time, when it stops flashing, do not turn the ignition off. Instead, turn the key from the "RUN" position to "START". The engine should start and run. The computer has now learned the new Passlock code.
Please help myself and others by taking the time to rate my answer. Thank yoou for using fixya!
Feb 08, 2011 | 2003 Pontiac Grand Am
Why wont my car start even after i tried the security reset. i turned key to on position for 10 minutes turned it off then tried to start it 3 times. security light still flashes
turn the key on and wait till the security light stops flashing ( this could take as long as 30 minuets ) then turn the key off then back on but do not try to start the engine and wait till the security light stops flashing ( again this could take as long as 30 minuets ) then turn key off then turn key on and start engine.
Jan 31, 2011 | 1996 Buick Regal Olympic Gold
My 2002 Grand am is have a passlock problem. The
I discovered the hard way- ($85.00 later) Step 1: turn key to "on" position. step 2: open driver door. (security light should be flashing on and off) step 3: wait ten minutes with key in "on position and driver door open. step 4: when 10 minutes is up-(youll know-because security light will have stoped flashing after 10 minutes) close driver door ,turn key to "off" position, then turn key "on" to start. drives me crazy!! I have to do it to mine sometimes 2-5 times a day! GM doesnt have a fuel reset button etc. like fords do.
Jul 17, 2009 | 2002 Pontiac Grand Am
Computer won't turn on
A flashing yellow power LED is an indication of a failure in the power supply. If under warranty, Dell should be replacing it. If out of warranty, then a 400/450 Watt ATX power supply should resolve the issue.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182021
Apr 06, 2009 | Dell Dimension™ E510 PC Desktop
Sony Trinitron
I am having the same problem my tv will not turn on all of the sudden, standby light flashing, cnnot get it to do anything
Jun 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Franklin MWD-1490 Dictionary / Translator Logo
175 people viewed this question
Top Franklin Office Equipment & Supplies Experts
Harrie
Marvin
Marvin
Arnie Burke
Arnie Burke
Are you a Franklin Office Equipment and Supply Expert? Answer questions, earn points and help others
