Question about Tomtom GO 300 GPS Receiver
No sound comes out of the speaker. The volume settings are correct. The sound is on, and the volume is all the way up. What can I do?
  • Monty74 Jan 20, 2008
    Hi I have the same problem on a 910. Plays songs and warning tones but no sound comes out for directions. Please help!
    Novelist:
  • 158 Answers
Your problem can be one of several. 1/ you have lost / deleted / corrupted the voices on your SD card. if there are no voices then you won't get any nav instructions. 2/ Your speaker has stopped working , if faulty it will need replacement. ( not unknown and common on early tomtoms ) . On other tomtom models that have an external speaker socket the socket becomes faulty. This socket has a switch that switches the internal speaker OFF when an external speaker is plugged in. If this switch is stuck OPEN then that connection to the internal speaker is lost. However , the Tomtom drums sound is connected to the speaker via a different route so doesnt get switched off by this socket switch so the drums can still be heard.
Posted on Jan 29, 2008
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is...
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Jan 20, 2013 | Logitech LS-21 2.1 Speakers
Can't get sound out of my speakers although sound registers as playing
Check that your computer isn't muted and the volume on the speakers is up. Check that the plug for the speakers is connected correctly. Check to see if the sound card that the speakers are plugged into is set as the default in the control panel. Is there any sound coming out of the front port (earphones). Try another set of speakers.
Jun 06, 2012 | Computers & Internet
Sound is not coming
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 27, 2011 | VIA ASRock K7VM3 Socket A/...
Speakers were working,then i pressed something to see if was gonna sound different and now i cant find my way back to what it was...sound is coming from the computer to the tv,,but external speakers have...
also
hope it helps
Sep 22, 2011 | Logitech X-230 Computer Speakers
My laptop is a acer extensa 5220, sound is not coming on, so what will i do or how will i install the sound device
also
Sep 20, 2011 | Computers & Internet
I have checked and rechecked the setup and I am getting no sound. I have sound signals from my soundcard but no sound coming from my speakers. They are on. The power cord is plugged into a fonctionnal...
also
hope this helps you
Sep 19, 2011 | Logitech Z-2300 Computer Speakers
Left speaker is not working on my 2.1 speaker system...
A few things can cause this to happen. First we should check the computer. Take a pair of headphones or other speak set and check if sound comes from both sides. If to then the computer output is correct, else the computer is channeled to output to one side.
To change sound settings, if this is windows, go to your control panel and look for sounds option. In there you can change speaker settings, change volumes. On the volume control you can balance the speaker output. center the slider to make both correct.
If sound is coming from the PC correctly with a test object you will need to check your speakers for a fade option, not many have this it is just a suggestion. If no fade option exists, make sure the plug is totally seated. Improperly seated plugs will cause only 1 channel to be outputted or none.
If all the above does not help then check the cabled leading form the computer to speakers for damage as well as checking the wire between the left and right speakers for damage. Many times the output lead from the right to he left gets damaged from stress or other things and will stop output. Wiggle and pull the wire gently in each direction if they don't physically look damaged to see if sound is produced. if it is then the wire is internally damaged or loose from the speaker.
good luck
Mar 14, 2010 | Altec Lansing Audio Players & Recorders
System has power and cd's spin but no sound coming from the speakers. checked all connections and tried speakers with a different system they work fine. Please advise, Frank
First, check volume levels in mixer, both output volume and cd input volumes...Go to control panel>sound and audio devices>hardware and check to see that your sound card and drivers are working properly. Use troubleshooter if devices are disabled or not working properly. Make sure advanced settings for sound are correct for your speaker type....
Also see this article: http://support.microsoft.com/kb/307918
or search sound problems vista for alternate article.
Apr 20, 2009 | Audio Players & Recorders
Speakers are plugged in correctly, lights on but still no sound
Check your output jack again and make sure its on the green jack
and also check your speaker wires, if okay then check this;
For Windows XP;
  1. Go to Control Panel
  2. Sounds and Audio Devices
  3. On the Volume tab under "Device volume" check that sound is NOT muted
  4. Adjust volume control
  5. Check "Speaker Setup" under "Speaker settings" under the "Advanced" button
For Vista:
  1. Control Panel
  2. Sounds
  3. Select Speakers then properties
  4. Make sure device is enabled
  5. Test sound
  6. Adjust volume controls
Under Device Manager make sure that under your sound card that you dont have a yellow exclamation. Yellow exclamation indicates you need to install the correct driver.
Jan 18, 2009 | E-Machines T6420 PC Desktop
Tomtom GO 300 GPS Receiver Logo
158 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
