Question about Car Audio & Video
Car stereo im trying to build
I want 100 - 150 watts rms 6x9 for back deck and 6 1/2 for front door . i was looking at mb quart qsc216 and mb quart rce269 or infinity kappa 639.7i and infinity kappa perfect 6.1 6.5 . front door is componet . i want to keep factory look . other then trunk were sub and amps goes.
sub i was looking at kicker solo baric L7
{ im not an expert so im open for sugestions }
what do u think is a better idea or what should go with . i want great bass + sound qulity . i want some what close to compition even though i dont do compition.
car is hyndia elantra 06
im looking for 1x 12" sub 1x amp for sub
1set of 6x9 1 set 6 1/2 1x amp to push them
    Problem Solver:
  • 14 Answers
I guess the question you need to ask yourself then is how much money are you willing to spend? If you are looking for a sound quality system then it WILL cost a lot more than a DB all out BASS system. The system that you have picked out isn't a bad one but as with all systems this in only half the story. You will need to have it installed well to get the best from the speakers that you have chosen too. If you want to have the stealth look in the cabin then it's pretty simple, but you will not get the best sound quality or should I say imaging as the OEM locations usually are no good for this.
I would suggest that even though you keep things looking stealthy in the cabin apply sound deadening to the doors as Asian cars are generally quite tinny unlike German cars. This will make a big difference in terms of overall sound quality & help keep out the road noise so you can hear every little detail of your personalised system.
Posted on Dec 28, 2007
I'm new to the Car Audio seen.I just bought four 6x9's.Now I need a good Amp to push all four of them.Here's what I have.Sony XS-R6945 4 Way 6x9" 800 watt Full Range Car Stereo Speakers Power...
Look for a 4-channel amp that pushes 50 watts RMS @ 4 ohm.
Make sure the amp is CEA-2006 compliant.
Ignore peak or max watts as these are arbitrary numbers.
More info here -
Jan 24, 2015 | Car Audio & Video
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
Hello again. Sorry to say my knowledge is lil... I want to replace stock deck. Here is the stuff i want to put in it. Could you take a look and give an opinion if maybe i cant get away without putting a...
ok as for the deck just get the wiring harness for your car so you dont have to cut the old one out and that would eliminate the need for a wireing diagram with that done you should be able to hook all speakers you want to the stock spot so for a tweeter just hook it up with the door speaker there arnt any extra will only need a amp for a subwoofer unless you choose to put your mids and highs on one and if you didnt want to change your deck hook up the tweeters would be the same way hope this helped
Mar 30, 2010 | Car Audio & Video
I have a boat with Clarion CM1635 speakers, how do I size the amp for my speakers
Hello cgregerson,
If you are running just the front channels to 2 CM1635's, you will need a 2-channel marine certified amp with approximately 50 watts RMS output per channel.
The MB Quart NAU-260 here would be a good inexpensive choice.
For a little more power and quality, I'd recommend the JL Audio M2150.
To run both front and rear channels, you need a 4-channel amp with 50 watts RMS per channel.
The Kicker MX350.4 marine certified amp would be a good choice.
Hope this helps.
Oct 14, 2009 | Cyclone Car Audio & Video
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
I need help on sound built in
u may be able to custom fir the 6x9 into the rear of the vehicle, if you don't want to do that, you may be able to fit them into the spots in the doors, but that still may be a custom job. u could always go with boxes, individual boxes that you could put on the floor on maybe on the back deck where usually the 6x9s would be located. if you dont like that idea, you might try a body shop or electronics retailer because there is definitely a way to fit those speakers in the doors or on the rear deck, it just won't be an easy job for a beginner, you have to cut holes
Aug 09, 2009 | Car Audio & Video
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Dec 29, 2008 | Eclipse Car Audio & Video
Will this amp push my speakers
Whoa, I do belive your rating for your speakers are inflated. I have never heard of a 6X9 accepting 800 watts thats just rediculas, its more than my 12" sub needs. Anyways, if this amp is anywhere from 300 to 500 RMS watts you will be fine. Because the speakers are small they need very little wattage to reach there potential, usually less than 100 Watts each, and probably around 50. If you think about it most decks put out 50Watts max for each channel, because that is the max you can assume that the RMS wattage of the unit is only around 20-25 Watts of power per speaker.
Mar 25, 2007 | AudioBahn A4401Q Car Audio Amplifier
Car Audio & Video Logo
114 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
