Question about GE 30 in. Profile JP989 Electric Cooktop
Bunt food the 9 inch burner stays on hi and will not modulate its heat setting ( it comes on and stays on ) . this element has the option of being a 6 inch , or nine inch. the element will shut off when turned off .
  • 1,314 Answers
Replace the element
Posted on Dec 30, 2007
Main oven does not heat at all
Sounds like the heating/starter element went out. This item is very delicate and will break if touched. They are used on almost all newer gas appliances. It takes about 3 minutes to check. Turn the oven on and look down near the burners with all of the lights in the room out. You should see a glow for a while, then it will click off for a while and then come back on. If not, then turn off the oven and get a flashlight and look for the starter element to see if it is broken. It is about one inch wide, two inches long, and 1/4 inch thick. If you do get a glow then this is good news, the element is not broken. However, the element operates a thermostatic switch which operates the gas valve. This switch may be broken. The switch and the starter element usually come out together when removed.
Jan 13, 2014 | Thermador PRL486EDPG 48in Pro-Grand LP...
Element on light on ... Nothing is on
This happens when one of the infinite switches short out. The indicator lamp will remain on even though none of the elements are heating up. To figure out which one is defective, gain access to the rear of the switches and remove the wire going to terminal P (Pilot) Restore power and see if the light is out now. Keep doing this to the remaining switches until you find the one where the light stays out with the wire removed after power is restored. Supply model number and we will supply the part number for the infinite switch. Be sure to let us know if it is the 6 or 8 inch burner switch. Good Luck and be careful. Eric
Mar 23, 2012 | Frigidaire Cooktops
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 | Cooktops
Stove top will not heat oil hot enough to fry foods. Burner continues to re-cycle on and off while switch is on high. Burner gets red hot for a few seconds then turns off for a few seconds, then back on.
You may have a cracked element, they expand when heated and cause a separation in the element. You really have to put a voltmeter on it to test it under load. If the voltage remains constant while the element is heating and cooling, then indeed you have a bad element.
If you don't have a voltmeter, or don't want to perform this test, buy a heating element and replace it, if you have the same problem, you'll have a spare element
May 14, 2009 | Jenn-Air JED8430 Electric Cooktop
GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Mar 02, 2009 | GE Cooktops
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Maytag MER6770aaw
if the 9inch dont cycle off and on like the others and the 6 dont work at all replace the element
Dec 28, 2007 | GE 30 in. Profile JP989 Electric Cooktop
Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Nov 10, 2007 | GE 30 in. JP340 Electric Cooktop
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
GE 30 in. Profile JP989 Electric Cooktop Logo
167 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
