Question about JVC TH-A10 System
JVC TH-A10 Hi, I have a JVC TH-A10 home system and wish to know why this system do not want to play Audio copies or any CD-R cd's. I copied to a CD-RW cd the other day and it worked but only with a 1x-4x speed. Do you have any other sugestions or better ways to play copied audio cd's on the th-a10? Kind RegardsAnton Swanepoel+27824939461Email address: arswanepoel@fnb.co.za
This unit only plays region specific material.
Posted on Jan 19, 2008
Have the same unit and it does not have the capability to play anything other than commercialy produced CD's or DVD's i.e. no CD-R CD RW
Posted on Jan 08, 2008
Can copy from analog sources, but can't copy from digital source, eventhough the signal is monitored. The display says "can't copy".
Media
The unit requires Digital Audio CD-R or CD-RW media for
recording. Computer CD-R or CD-RW discs do not work with
this unit.
Serial Copy Management System
This unit is in compliance with the Serial Copy Management
System standard. This standard has been established to
restrict digital-to-digital copying to only the first generation.
The basic rules governing this system are as follows:
Rule 1
A digital recording is possible from a digital source such as a
CD, DAT or MD onto a recordable CD-R, CD-RW, MD or DAT
through a digital input connection. However, further digital
to- digital recording is prohibited for the second and later
generations.
Rule 2
When an analog source such as an analog disc or FM
broadcast is digitally recorded by using a CD-R, CD-RW, MD
or DAT, this recorded source can be digitally recorded on
another CD-R, CD-RW, MD or DAT. However, further digital
copying is prohibited.
Download the manual "cd-rw880_ef_manual.pdf" on the page linked below:
Download free pdf for Teac CD RW880 CD Player manual
Aug 22, 2013 | Teac CD-RW880 CD Recorder
I have a (jvc dvd digital cinema system th-s3). that will not play original dvds however it seems to play copies and cds just fine in fact all other functions work correctly. i have tried a lens cleaning...
I have the same system. I've had no trouble until a year ago, then the system got particular about when it wanted to play DVDs. I've also used lens cleaner to no avail. It plays some DVD's but plays all CD's and some copies. It has given me good service but cost me a lot of money. I hope there is a simple solution to this.
May 17, 2011 | JVC TH-S3 System
How do i get my th-a9r to play dvd-rw
You can't. The Laser will only Play +R & +RW.
Non-playable discs
• DVD-ROM • DVD-RAM • DVD-R • DVD-RW
• CD-R* • CD-ROM • PHOTO CD • CD-RW*
* Audio formatted CD-R and CD-RW can be played.
• Playing back discs list as "Non-playable discs" above may
generate noise and damage speakers.
Apr 23, 2011 | JVC TH-A9 System
Where can I get CD-R's that will work on this machine in Australia these days? ie Are there any non audio marked CD-R's that will work in it? I have tried Verbatim and TDK CDr's without any success. I have...
I don't know about availability of CDR-A or -Music in Australia but they are the only media that home CD Audio Recorders are designed to use.
Regarding the CD-RW Audio disks - I've used them for quite some time and do eventually get uncorrectable errors on them but never No Disc displays. Just the same, I don't consider them reliable enough for vital long term storage of music and use my PC to copy them to a CDR as soon as I can. Being a data- rather than real-time-music copy, I reckon the PC may be able to retry errors it encounters and maybe correct them during the copy.
Feb 06, 2010 | Marantz DR-4050 2-Disc CD Recorder
Can u help me to fix my problem on HL-DT-ST RW/DVD GCC-4522B Problem, when i copy an audio cd from the cd rom and then save to the folder the audio file that i copied was unable to play even in any...
you cannot just copy the audio track from the audio CD, RIP it ur convert it into mp3 or wma format by using and mp3 converter or in the windows media player, you can RIP there to copy the music from you music CDs.. Good luck!
Jul 16, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
MY UNIT WONT PLAY CD'S
are they store bought CDs ? or are they copies? cause some players unless stated will not play MP3 or MP4 cds, or CDRs , CDRW Etc.... check if the Cds are burned copies, and then also check the music layout if copied, using the computer, see if they are mp3 files that should play if they are mp4 then the cd will act blank....hope this helps...
Jun 28, 2009 | JVC KD-SX950 CD Player
MultiBay drive will not allow me to copy on to CD
You may not have the correct discs,check type of discs it takes,ie CD-R,CD+R,CD-RW,CD+RW.
Jan 08, 2009 | HP Multibay (DG189A) DVD-RW Burner
Unit will not play DVD's or CD's
no video. audio is good, connections are good.
Jan 19, 2008 | JVC TH-C3 System
Problem with original dvd
Before performing any operations, make sure of the following: ? Check the connection with the TV. ? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen. ? For DVD playback, you can change the Setup menu setting to your preference menu... Alos, make sure thay the system and disc region code numbers are incompatible: The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers. * Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
Dec 15, 2005 | JVC TH-A5 System
JVC TH-A10 System Logo
262 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
