Question about Dell Dimension 4500 PC Desktop
No power I replaced mother board with a refirb, replaced power suppy and fan and it is still dead. Some one said it could be the switch on the shell. How likely is this? Or is it bad refirb motherboard?
    Problem Solver:
  • 18 Answers
IT is most likely the Bad Refirb Motherboard or it can be the Power Supply. if the power supply turns on. than it is the Motherboard. if it doesn't than it is the Power Supply. Make sure you connect the power switch to the motherboard. the newer motherboards are more switches than the old Motherboards!
Hope that helps.
Posted on Dec 26, 2007
My dell xps420 does not turn on, no switch power or light, i have working internal lights
there're a couple of reasons for this.. maybe the motherboard and the new power supply is incompatible.
try removing the power cables for all the drives, just leaving the graphics card and ram seated. see if you can get into the bios. if you can, means the power supply u used is not enough to power the drives.
otherwise, try removing a component at a time to see where is the problem. try to get to the bios and hear for beeps. they should be tell-tale signs.
Dec 08, 2011 | Dell XPS 420 PC Desktop
PC with ECS P4VMM2 V5.0A motherboard won't power up after working for years. Power supply fan doesn't come on, case fan doesn't come on, PC dead. Tried replacing power supply, same result. Power supply...
The mother board and the fan also need replacement. If you have recently added any other hard ware to the machine, remove it and try booting again.
Apr 11, 2011 | Computers & Internet
The motherboard comes on when the power suppy is switched on. even with no ram or hard disk it turns on and gives no beeps.
this issue is a possible mother board going bad or a power supply switch that is "open and needs replacement. I tend to go towards the latter. Replace the power supply.
Apr 22, 2010 | Biostar NF325-A7 Motherboard
Humming noise coming from the freezer area increases in volume then decreases in volume
Your refrigerator uses a 2 speed DC evaporator fan. The electronic control board determines when it should run at high speed, and when it should run at low speed.
Mar 30, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
Emachine t3958
First check to see if a drive died. Unplug all the drive Floppy, hard and dvd or burns. I have come across many time that a drive will die and keep motherboard from booting. Being that you say you get a green light on the motherboard shows that the power suppy is providing some power. But for some reason the internal self test is faulting the power suppy. I have not come cross any bad power supplies killing a motherboard. But I have come across power supplies killing drives. The power switch is a normal open switch so the only time you be able test continuity on it is if you hold the switch in, or the closed position.
Apr 03, 2008 | E-Machines eMachines Desktop PC
Help
is the power switch connected properly to the case button ?
http://www.rhyshaden.com/images/intspkr.jpg
an example above this would prevent it from powering if it has been knocked of the jumper
Mar 20, 2008 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
System will not power up
Have you replaced the cmos battery(disc shaed flat 3V CR2032), although there could be more sinister problems than this as the mobo or processor may be damaged.
Feb 12, 2007 | Intel D845EPI (INTELKD845EPILPAK10)...
Dell Dimension 4500 PC Desktop Logo
116 people viewed this question
Alun Cox
