The coffeemaker will grind but the water just sits in the reservoir. I have unplugged it and turned it off and on, but nothing happens. The buttons light up so there is electricity. It is about 4 years old and has never had this problem before.
my grind and brew doesn't make a strong cup of coffee anymore! It worked fine for a year, I clean it...
(More)
my grind and brew doesn't make a strong cup of coffee anymore! It worked fine for a year, I clean it all the time it just makes weak coffee now!
We have a Cuisinart Grind and Brew machine that has stopped working. Specifically, you turn the...
(More)
We have a Cuisinart Grind and Brew machine that has stopped working. Specifically, you turn the coffee maker on, but it turns it's self off. It sounds like a switch problem. Has anyone else experienced this? We hate to trash the machine if it's fixable.
The water doesn't empty from the machine into the carafe and it leaks all over the counter while it...
(More)
The water doesn't empty from the machine into the carafe and it leaks all over the counter while it is brewing. I've tried brewing boiling water through it or pressing it several times until all the water moves through it, but it seems to be getting worse. I've turned it upside down, tried to sponge it out, even tried to open it up. Hopeless.
