Bad copies Hello, I have an old xerox 5309 copier, which I inherited.  I.m experiencing two problems with it. First, when I press to copy the paper jams and I a "P" message comes in the screen. I press the copy button again and it works. It does so intermittently. the second problem is the copies come out two dark even at the lowest setting . Please advise.
  • 417 Answers
This seems an easy one the first problem you are getting is that the paper pickup rollers are worn or just dirty easy way to clean them is to place one piece of paper in the tray and at the leading edge spay on some cleaning fluid about a inch wide. Then press the copy button and the machine will jam. Open the door and repeat a few more times. Once finished remove sheet of paper from tray and wipe dry.
The other problem is merely down to dust on the copy mirrors. Remove the top glass normally two screws on the right hand side of the copy glass. Once removed glass place in safe place. In the machine use a cloth on the mirrors you can use windowlene or some other kind of glass cleaner. (DO NOT REMOVE MIRRORS) clean all then clean glass and replace the copy should be clean. (NOTE!!!!! There should be about six mirrors so make sure you clean them all)
Oh and be careful machine should be off when doing above.
Hope this helps
J
Posted on Dec 26, 2007
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox 416 Work Centre Pro Paper Jam
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
SAM ANDERSON
Sep 23, 2008 | Office Equipment & Supplies
Xerox 5309 - ghost image on the second half of the print
Has to be a roller problem. First check that the drum is being cleaned properly by the drum blade, it is responsible for cleaning the leftover image of the copy/print before it ( when you remove or look at the drum you should not see an image or toner ,it should be clean , if not replace  drum and blade). Next check that the upper fuser roller is not damaged ( This is the rollers that heat up and fuse the image into the paper  ). If these check out it could be the erase array or laser unit ...Good Luck
May 03, 2009 | Office Equipment & Supplies
Xerox Regal 5790 Paper Jam
Wat is the code about this problem 08-300 its maine the Füser is not start on the same time when the cluts is not werking oder the pall is not gooing to this point open the front dore an you cann sche small cluts this is no good contact of its not working then you can puss the small wiel to the bik rol en the paper wil to the füser turn the green wiel and the paper go to füser out. I had this problem also with Xerox 5760 the same .
Apr 10, 2009 | Xerox Office Equipment & Supplies
Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at jagpal_65@yahoo.com
Dec 25, 2008 | Xerox XDL-33D Black and White Copier
Clicking sound and crumpled paper
Bad heat roll drive gear in the fuser. Very common problem.
Look up on google a business called "The Parts Drop". Ask for Britt, part is $13 or $14.
Aug 31, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Fuser Assembly for Xerox Copier 5309 PN 126K3410
Right here
https://www.partsdrop.com/store/
Use that link, ask for Britt, he will fix you up. Tell him Rick said Hi. Haven't talked with them for a while..
Jun 13, 2008 | Xerox Office Equipment & Supplies
133 people viewed this question
k24674
Marvin
Marvin
