Question about Garmin StreetPilot C330 GPS Receiver
GPS GARMIN 340 turn it off by itself.
My GPS is not wworking. When I turn it on it inmediatlly turn it off, even though it is laready conected to the power.
  • 174 Answers
Does the unit comes on by itself once power is applied to the unit? If it doesn't come on by itself, then there is a problem with your power supply. The unit is designed to detect when an external power supply is applied and turn itself on. It is also designed design to detect if you unplug the unit from the external power supply. It will say "Lost external power, shutting down in 30 seconds". BTW are using Garmin cables?
Posted on Feb 01, 2008
I unplugged cable to computer during first update This is a garmin zumo 340
Try doing a Hard Reset
  • hard reset zumo 340 en 350 - YouTube www.youtube.com/watch?v=tWUDsiXu9QI
    • BY MRGPSNL
    • 6 MIN
    • 10K VIEWS
    2014-03-20 · Met een hard reset breng je je toestel terug naar de fabrieksinstellingen en is je apparaat weer ... hard reset zumo 340 en 350 ... Garmin Zumo ...
  • zumo 340LM ' Garmin buy.garmin.com > Shop > Automotive > Motorcycles Garmin Connect lets you search, plan and share your rides. Get Started /en-GB/GB/accessoriesAndMapsUrls/010-01043-06.ep. Customer Service. Product Support;
  • Hard reset Garmin Zumo 220, 550, 660 - YouTube www.youtube.com/watch?v=g9h9QtWWedk
    • BY MRGPSNL
    • 4 MIN
    • 25K VIEWS
    2014-03-20 · Met een hard reset breng je je toestel terug naar de fabrieksinstellingen en is je apparaat weer 'als nieuw ... Hard reset Garmin Zumo ...
  • Garmin zumo 660 665: How to Reset Video - GPS City www.gpscity.ca/videos/play/Q0td7d4BH9A How-to video for the Garmin zumo 660 665: How to Reset Video explaining its functions and installation.
  • http://www.bing.com/search?q=garmin+zumo+340+reset&qs=n&form=QBRE&pq=garmin+zumo+340+reset&sc=0-21&sp=-1&sk=&cvid=3C4EE77095704DEC935AD44372BE0B4D
    May 11, 2016 | GPS
    When I start off the bpm goes up above normal then levels out after approximately 300 yds
    This is basically the forerunners way of callibrating itself. It picks up the heart rate signal from the chest strap, sets itself high and then drops down until it matches the signal coming from the transmitter. This seems to be a feature in all the forerunner series though the Garmin reps I asked about it( I work in an outdoor store) weren't even aware of it and didn't seem too concerned even though staff who tested it had said it was annoying.
    Oct 06, 2009 | Garmin Forerunner 305 GPS Receiver
    Garmin nivi 200 won,t turn on
    The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
    - Jim
    Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
    Garmin c 340 froze- what do I do
    This solution is for c330 but it should work the same...
    It took a nap...
    Waking up your c330...
    If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
    Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
    Installing version 5.70
    I found out through own experience that if it was purchased at wal-mart garmin told me that no updates were available at this time.
    Jan 13, 2008 | Garmin StreetPilot C330 GPS Receiver
    Will not turn on
    Champ...If your 340 stops responding, try turning it off and back on.If this does not help, reset the 340.
    1.Unplug the power and the usb cables to remove external power.
    2.Place your thumbnail in the groove located under the Garmin logo on the faceplate and gently pull off the faceplate.
    3.Press the reset button for about 3 seconds.
    4.Connect the 340 to a power source using power cable. The 340 should automatically turn back on and operate normally.
    Good Luck ... Ginny
    Dec 26, 2007 | Garmin StreetPilot c340 GPS Receiver
    Ihave a 340 thats programmed in Russian
    If you cannot change the language on the Receiver itself you need to download new language "pack"
    You can find those here: https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00401-20&cID=164&pID=290
    Hope that fixed it, please rate.
    Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
    I cannot even tunr on my brand new fresh out of the box street pilot 340? Any ideas?
    there is a red button on the side of the unit, hold that and the unit will come on.
    Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
    Garmin 340 streetpilot won't even turn on?
    I had the same issue with mine during a trip. Probably needs to be reset. See page 31 of the users manual on Resetting your c340. Once I did this it worked fine.
    http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
    Garmin StreetPilot C330 GPS Receiver Logo
    337 people viewed this question
    Top Garmin GPS Experts
    Marvin
    Marvin
    Steve
    Will Halftowaite
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
