http://www.pcworld.com/product/29398/dell_inspiron_e1505.html?p=specs
Kel,
1) Left-click on Start
2) Right-click on My Computer.
3) Left-click on Properties at the bottom of the list.
4) Left-click on the Hardware tab.
5) Left-click on Device Manager
6) Left-click on the + sign next to Disk drives
7) Right-click on the name of the optical drive -
TSST TS L632H
(Name and model number, actually. may just have TS L632H )
8) Left-click on Properties
9) Left-click on the Driver tab
10) At the bottom left-click on Uninstall
A Microsoft 'squawk box' will come up.
"Warning you are about to uninstall this device, ya-da, ya-da."
Left-click on OK.
Close all windows. Go back to your desktop screen. Turn the computer off.
(Start > Turn Off Computer > Turn Off )
Wait 1 minute. Turn the laptop back on.
After Windows has fully loaded, (And all the programs you have in the Start menu), you should see a pop-up out of the system tray.
"Found IDE/ATA device", and perhaps another one after it,
"Found TSST TS L632H"
No?
Suggest you remove the optical drive, and reinstall it again.
Not that big a deal. One screw, and it slides out. There are contact pins that may be 'corroded'.
(They are gold plated. Gold isn't supposed to corrode. My word )
By unplugging it, (BY sliding it out), and plugging it in again, it will help clean the contact pins. Mostly it helps ensure the optical drive is plugged in tight.
http://support.dell.com/support/edocs/systems/ins6400/en/sm/index.htmOptical Drive
http://support.dell.com/support/edocs/systems/ins6400/en/sm/opdrive.htm#wp999869
Still no? You need a new optical drive.
http://www.discountelectronics.com/index.php?l=product_list&c=3554Just from a quick search.
For additional questions please post in a Comment.
Regards,
joecoolvette
Thank for replying to my problem. Sorry to say no good .
The case has room for two optical drives mounted vertically, snd yes it uses locking sliders which you attach to the drive similar to many I've used. with the sliders on the drive has got no chance of fitting way too big. Without the sliders fitted the drive is such a tight fit I can only push it in about a centimetre I'm a bit of a gorilla so it not for want of pushing hard enough, It just seems too small thanks in advance
