Question about SanDisk Sansa e200 MP3 Player
Sansa e 200 locked up, where is the rest button? how do i unlock it?
Locked up brand new sansa e 200, just opened this am, how do i unlock it, downlowded many songs, stuck on highway to hell?
  • Bluberrygal Jul 26, 2008
    charged all night played 2 songs and locked out. Battery low shutting down message. Now will not charge will not come on. It is dead
    bluberrygal
  • 8,596 Answers
Slide hold to center, hold power for 3-5 seconds
Posted on May 26, 2008
When I press the power door lock button, the only door that will open is the driver's door. The other three doors remain locked
you have to press the unlock button twice, the first push opens the drivers door, the second unlocks the rest of the doors.
Jul 26, 2010 | 1989 Buick Park Avenue
When turning on the Sansa e260 it is now in the Key LOCKED mode
I had a similar problem with my e250. The problem was that one of the plastic arms on the lock switch had broken off. The one that locked it was still in place but the other wasn't, so I could always lock it but never unlock it.
Since you already know how to open the case, take a look at the switch at the top. Use a pen or something and slide it to the unlocked position (away from the headphone jack). Put it back together and see if it works. If it does, just remember never to lock it again.
Mar 10, 2010 | SanDisk Sansa e260 MP3 Player
Central locking went on my lexus took it the garage they said the key wouldn't reprogramme is there anything that can be done
Programming
When
Key added or replaced. System malfunction.
How
Driver's door open and key removed from ignition switch. Insert key into ignition switch, then remove it. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Close and re-open driver's door. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Insert key into ignition switch. Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes. Remove key from ignition switch. System should now lock and unlock vehicle, once or twice depending which mode has been selected. Within 40 seconds: Simultaneously press and hold key lock and unlock buttons for a maximum of 1,5 seconds. Within 3 seconds: Press any key button for a minimum of 1 second. System should now lock and unlock vehicle once.
Manufacturer: Lexus Model: IS 2,0 200 Engine code: 1G-FE Output: 114 (153) 6200 Tuned for: R-Cat Year: 1999-05
© Autodata Limited 2009 25/02/2010 V8.207M-ukad113581
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat programming procedure.
Within 40 seconds: If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Close driver's door or insert ignition key. NOTE: A maximum of 4 keys can be programmed
Feb 25, 2010 | Lexus IS Cars & Trucks
My sandisk e250 sansa mp3 player does not boot. shows only SanDisk logo. My computer also do not detect the player as new hardware.
  1. Turn off player.
  2. Slide HOLD button to locked position (towards headphone jack).
  3. Press and hold RECORD while connecting to the PC.
  4. Release RECORD when you see "welcome to recovery mode" on the player's LCD.
  5. Open My Computer/Windows Explorer and see if you can find a new removable flash drive labeled "16MB-FORMAT".
  6. Right click on 16MB-FORMAT and select New Folder.
  7. Name the new folder "sansa.fmt" (without the quotes).
  8. Wait one minute.
  9. Reset HOLD back to unlocked position.
  10. Disconnect player from PC.
  11. Wait for player to reboot.
Jan 27, 2010 | SanDisk Sansa e250 MP3 Player
My sansa MP3 player is locked. How do I unlock
I loved that mp3 player, it's a great basic one. Anyways...
To unlock it, it require nothing related to your computer, it's on the side of your player, the old button.
Near the mic. I believe right now it's on a side with orange, tick it to the side that shows white. Open it again, should be unlocked.
Jul 30, 2009 | SanDisk Sansa m230 MP3 Player
My Honda CR-V EX 2005 doors lock by themselves. Occasionally, after you unlock it with the remote key, it locks itself before you can get in. It also happens sometimes when I unlock the car, then open the...
They all do it, its part of the security system that all the doors lock after a minute or so from unlocking if you don't open the driver's door.
It prevents you from accidentally unlocking the car door while walking away and clicking the remote in your pocket, the car re-locks on its own.
If you open with the remote then open only the rear door, the other doors all lock and when you close the rear the alarm goes off.
What fun we have!
Jan 02, 2009 | 2003 Honda CR-V
all you can really do is hardboot it. unscrew the screws in the back and remove the battery, then replace. i just did it with mine, and it loaded up properly and appears to be working....
Dec 25, 2007 | SanDisk Sansa e200 MP3 Player
Locked
If the onscreen message says ?Locked? and then shuts off, you need to locate the Hold Button on the left side of your player. Slide that button up to unlock your device.
Aug 09, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
