Question about SanDisk Sansa e200 MP3 Player
Sansa e200 for christmas wont connect
All computers i connect it to does not recognize it. It does not connect. It says everything was installed and its ready to use but does not show in the computer.Please help!!!!
  • Anonymous Dec 26, 2007
    CHANGED USB SETTINGS NO JOY
    CHANGED USB LEAD
    CHANGED USB SOCKET
    INSTALLATION DISC IS IN DRIVE AS FAR AS I KNOW EVERYTHING IS INSTALLED. PLUGED SANSA E200 IN AND COMPUTER SAYS NEW HARDWARE FOUND AND ASK TO WIZARDED IT . I SAY YES. IT STARTS THEN SAY ERROR HAS OCCURRED DURING THE INSTALLATION OF DEVICE THE DATA IS INVALID.
  • 3 Answers
Make sure the USB portion of the menu is set to MSC. This should enable your computer to recognize the player.
Posted on Dec 26, 2007
MY COMPUTER IS NOT RECOGNIZING MY SANSA E260
Use the support site for e200 series from Sansa to get the e260 connected and follow the steps:
http://kb.sandisk.com/app/answers/detail/a_id/266/kw/recognize/r_id/101834
Manual for e200 series
e200v1:
http://mp3support.sandisk.com/downloads/um/e200v1_userguide_en.pdf
e200v2:
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
Need more help, just post a comment.
Oct 17, 2009 | SanDisk Sansa e260 MP3 Player
Wont recharge or even start! Help!
http://go.shopsansa.com/content/batterykit.Replace the battery.Everything you need to do it is at this link.This is a fixya solution please vote blue.RICHARDM69
Dec 26, 2008 | SanDisk Sansa e200 MP3 Player
Wont come on
Make sure the hold switch is not engaged.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa e250 MP3 Player
Did you try to plug the mp3 player in to the usb while the CD was in?
Jun 02, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 is not recognized by by computer
**** this sansa e260 the piece of **** froze on me twice and both times i took it back to circuit city and just got a new one. one suggestion when you do get this is keep the repeipt for it
Mar 31, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 locks up in refresh database during startup
if the computer can find ur sansa(or 16mb format) you should rightcliick and format it. this will delete ur music, videos, etc but it will make ur player usable
Mar 17, 2008 | SanDisk Sansa e200 MP3 Player
Uploading songs on it
you could try putting it into recovery mode if it's like the sansa e200 series. to do this plug it into your computer and click the hold button so the orange is showing. next, hold down the record button while pushing and holding the power button at the same time. after a few seconds it should go into recovery mode and factory settings will restore. this works for sansa e200's and i hope yours is almost the same as them. try the sansa forums though they could help alot.
best of luck
Feb 14, 2008 | SanDisk Sansa Clip MP3 Player
My computer doesn't recognize my Sansa E200
Make sure player's usb menu is set to MSC, so computer will recognize it. Not sure why, but sometimes it helps to try another usb port on the computer. Good luck.
Dec 29, 2007 | SanDisk Sansa e200 MP3 Player
Can't connect!
Has to be Windows XP for either USB Mode but im not sure whether u can connect it to other computers under different versions of Windows or not and I know Apple computers dont work at all with the Sansa E200 series. Also connect ur Sansa to the rear USB inputs instead of the front inputs. Something that has to do with power distribution if none of these call their tech support they were very helpful with my issue.
Dec 25, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
