Power Generators
Problem for Power Generators
Generic problem for all Power Generators
I can get my G1000M generator not running.
By bertconner3 on Oct 10, 2009
I can get my G1000M generator started as lond as I put carb cleaner in the intake of the Carb. As soon as I pull it away it cuts off. Checked gas lines and they are all clean. Please help.
Solution #1
posted on Oct 10, 2009
Not Rated)
Richie_asg1
Rank: Guru
Rating: 87%, 428 votes
Fuel - air mix incorrect. Clean airfilter, and probably adjust idle settings. Open way up while running to clear any debris in the needle valve - then close off again untill stall - open up and adjust for correct idle.
Was this helpful?
Yes
No
Popular Solutions for Power Generators
Questions and Unsolved Problems for Power Generators
Answer
I have a Kohler K-7 steam generator/shower and after using it just fine, water now just pours out... (More)
Answer
EU 2000i generator requires ether to start. After it warms up it is ok. A lot of ether here. short... (More)
Answer
Dear sir i want a solution how can we check the actutaor&magneticpickup&controller... (More)
Answer
generator has only been run about 30 min. Then it quit generating any power I was only running a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Power... Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
