It can be one of three things. Unplug and use an Ohm Meter to measure the resistance of the defrost heater that is mounted on the evaporator coil in the freezer compartment. Then disconnect the defrost heater and measure with ohm meter. It should measure in the 20 ohm range. If it measures as "open" replace the coil.
Next suspect is the defrost timer mounted in the front of the compressor compartment. It's tough to test, so I'd just replace the timer.
Finally, there is a sensor mounted on the top of the defrost heater that shuts off the defrost heater when it reaches a high temperature. If the coil tests OK, and you are going to replace the timer, you may want to replace the sensor too.
It is awkward to test, the temperature of the sensor needs to be be below room temperature to close. The cost of the sensor is low enough that you may not want to replace the timer, then test the system, and then have to go back in to replace the sensor later.
I'm looking for an upright frost free freezer in white with between 16 and 20 cu ft and temperature...
(More)
I'm looking for an upright frost free freezer in white with between 16 and 20 cu ft and temperature alarm.
freezer first started to warm up from the bottom up. then it stopped cooling all together. i changed...
(More)
freezer first started to warm up from the bottom up. then it stopped cooling all together. i changed what i think is the protector, but the freezer's compressor states it has a thermal protector. the small parts that i changed are connected to the compressor and contains 4 wires. when i turn the freezer on it makes a loud noise. but i also noticed that the compressor was loose because it was messing a bolt and another one was loose and it will not tighten.
Our 12 yr. old jenn air refridgerator freezer ice maker has not shut off twice and ran all over our...
(More)
Our 12 yr. old jenn air refridgerator freezer ice maker has not shut off twice and ran all over our kitchen floors. What can be done?
