hello i have a Envision LCD monitor that my sister gave me but when i hook it up and turn it on , it stays on for a few sec then goes off. can u tell me what might be wrong with it or if its worth fixing
thank you
Comments:
Dec 26, 2007
- my monitor comes on when i push the power button but then it goes back out it wont stay on long enouth 4 me 2 do anything, can u help me with this problem i just dont know what else 2 do when it
-   I have a ProView PL17 LCD and it does the same thing?-   jimmymac45
Mar 01, 2008
-   The monitor stays on for 6 min then cuts out.A flick of the power switch and it tries to start,but flashes a screen and fails.Noticed a small hiss when trying to re start.After leaving it for a minuet it starts ok then again fails.Checked circets with multimeater seem ok.Hissing comming from inverter area. stummped.-   remmrick
Most likely the 2 470uF capactitors in the power supply have leaked and partially shorted. If you have those replaced it should power up fine. The symptoms will be the green power light will come on and the backlight tubes will light up for about 1 sec then the entire monitor will shut off.
My RLT1720, has started randomly cycling through the signal inputs AV1 - AV2 - TV - PC, etc. Is it...
(More)
My RLT1720, has started randomly cycling through the signal inputs AV1 - AV2 - TV - PC, etc. Is it repairable? TV is approx 5 yrs old.
how do you tune a relisys tv I have done an auto tune but need to tune manually fine tune has a...
(More)
how do you tune a relisys tv I have done an auto tune but need to tune manually fine tune has a limited band
