Question about Kenmore 57029 Side by Side Refrigerator
Kenmore coldspot freezer door water line
We were given a kenmore coldspot 106.9505782 with the doors detached. It has a water spicket outside the freezer door with the water line coming up through the freezer door pivot that has been cut at an angle or disconnected. How do I attach this line and hang the door? Thanks
  • 2 more comments
  • Anonymous Nov 26, 2008
    I have the same problem with a GE side-by-side refrigerator.
    The water line to the H2O dispenser has been cut at the door pivot point...
    We can't figure out how to replace the line inside the door. Any advice?
  • patrharrell Mar 27, 2009
    I have the same problem with a kenmore side by side refrigerator
    The water line to the H20 dispenser has been cut at the door pivot point... we cant figure out how to replace the line inside the door.
  • midnite owl Apr 04, 2009
    Sorry about the typo error,,but where it begins above w/ ("so far so good and when") was a typo that i forgot to correct. The sentence or words before that should read, I then had to cut a small piece out of the front guard etc, etc, ...good luck!
  • gsimm Apr 04, 2009
    I was able to take door a part and run whole new line. Wasn't easy because of foam but I was able to attach new line to old and pull old line which brought new line through foam. Basically what midnite owl did. Have not had a problem since. Except the shelves on the frig side, right side wants to come off. I took that door a part and put wedges between foam and the plastic to bring shelve pins closer together to hold shelves. Still if the shelves are just right they come off. I can't spread plastic and foam any farther. Pain in my pa toot.
    Problem Solver:
  • 14 Answers
I had the same problem and I would like to replace the whole line inside the door, it was best to get a double sided connector from an appliance parts store. The part cost me about 7 bucks. I then had to So far so good and when cut a small piece out of the front guard where the connector goes. you take off the front guard, measure where the tube broke. The connector comes off when you push one side down.Cut the edge of tube to have a straight edge, but just a little at a time. Just a clean straight edge, it does not have to be perfect!! I used a small pair of needle nose pliers to pull the bit of hose down from the freezer side and then i used my connectors. It just takes a little time and effort. Let me know what happens!!
Posted on Apr 04, 2009
I have a kenmore coldspot where can i fill the water in the fridge so i can get water out of the door
you have to run a water supply line to back of refigerator, there should be a 1/4 inch connector outside in back of ref
Aug 07, 2011 | Refrigerators
Kenmore, coldspot, model # 10650564991, side by side. The problem: spicket broke off of the water station on the door. My repairman/parts person says the part is $50.00! According to him/her, the etire...
The Technician was right. The part only comes as an assembly. See this link: (Item 10)
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10650564991/0582/0165000/P0050062/00008?blt=06&prst=0&shdMod=10650564991
Detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/4388152/0046/106/Model-10650564991/0582/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=10650564991&subCompDesc=Dispenser%20front&brandDesc=KENMORE&modelDesc=SIDE-BY-SIDE-REFRIGERATOR&pathTaken=partSearch&blt=11
The only thing I can recommend that you can do possibly save yourself some money is go to any local appliance repair shop an see if they are parting out a refrigerator. There is yet one other option and that is to call a local refrigerator recylcling place and see if you can obtain the fitting there.
Other than that the service person is going to order the NEW part thatis $55.74 + shipping from Sears.
The current available part number is: 4388152 and is called Nozzle Tube Kit.
This is the best I can do for you.
Thanks for choosing FixYa,
Kelly
Jan 14, 2011 | Kenmore Refrigerators
I know this is strange but here goes. I have a Kenmore Coldspot side by side Refrigerator. This past summer, it was leaking water out the front freezer door. We turned off the water and called a repair...
Turn off the fridge. Remove the freezer bins in the bottom. Defrost the drain line with a hair dryer.It is on the lower back portion of the freezer. Break up the ice on the freezer floor and dispose of it.
Discard any old freezer food. Change out the water supply line with a copper line if you are using a plastic line.
Dec 23, 2009 | Kenmore Refrigerators
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
636 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
