Question about Motorola Mobility E815
Losses network randomly
Boot up phone may or may not find network. Later it will find network for awhile but randomly losses network. Power off and reboot does not necessarily result in getting the network back. Have pulled battery and then re-installed battery and booted up but same result.
  • pastordon Jan 19, 2008
    Every few days when I turn on phone...fully charged overnight...it will not find the network. will turn off and turn back on and still no network. Seems to try to find it but cannot. Next day, usually has strong signal. Becoming frustrating. Any suggestions?
I have had the same problems. 6 weeks ago, the Verizon store was able to correct this for me, but it began happening again 2 weeks ago. I had them show me how they sort of fixed it, and they performed what the rep said was a "Soft Reset". This worked for a week. This last week, such steps allowed my phone to get full service bars, but only for one-three calls or text messages. This results in me resetting the phone frequently. Today, even that has failed. It may just be time to get a new phone. Anyway, if you want to try the temporary fix with your phone, here is how:
Settings>Initial Setup>Master Reset>Enter Security Code (default is 000000)>[Reset All Phone Settings]OK>Yes
Posted on Jan 30, 2008
  • 38 Answers
Signal transmitter is failing, not much to do when this starts to happen, no so long after it will stay with very low signal or non what so ever. and to have this micro resistors replaced might cost more than the phone actual value.
Posted on Jan 29, 2008
Would you mind sharing what you think is causing this problem? Thank you.
Posted on Jan 24, 2008
    Problem Solver:
  • 7 Answers
This is a somewhat rare problem with this phone and I don't believe you are going to get it fixed at a decent cost. I have seen it before.
The module attached to my phone keeps randomly not working than a day or so later( or even a few hours later) it just starts working again. What is causing this?
Check the connection between phone and module. You may just need to replace the module. Refurbs are just as good as new ones and a lot cheaper.
Nov 05, 2014 | Avaya Computers & Internet
Galaxy s3 won't turn on fully
Hello Sarah,
You can try these solutions:
Solution 1: Soft Reset(no data loss)
  1. Take out the battery and leave it there for 5 minutes.
  2. Reinsert the battery.
  3. Press and hold the power button for 10 seconds.
Solution 2: Replace Battery
  1. Take out your battery
  2. Insert new battery that you found from a friend or family with same model.
  3. Power on
  4. If it works,buy a new battery
Solution 3: Hard Reset(you will loose your data)
  1. Switch off the device.
  2. Press and hold Volume Up + Home Button + Power Key.After 2-3 seconds, release the Power Key.
  3. You will enter boot screen,use volume buttons to navigate and select Select Wipe Data / Factory Reset and then press power key.
  4. Select Yes.
  5. Reboot your device and wait to power on.
If nothing works you have to take it to your supplier.
Nov 28, 2013 | Samsung Galaxy S3
Low fuel pressure
Fuel Pump is overheating and Stalling
Apr 12, 2013 | Citroen Cars & Trucks
Can get started and drive it for awhile take it home and park it then 1 hour later try to restart it it want start
Those are the symptons of a faulty crank position sensor...they will cause a no start at random times and never set a code for the engine light to come on.
I hope this helps.
Jul 16, 2011 | 2004 Chrysler Concorde
05 chevy equinox , it goes into power loss randomly while driving.
When you say power loss, do you mean electrical power? Are your lights going dim?
May 28, 2011 | Chevrolet Equinox Cars & Trucks
I can't find any signal with my phone!
Firstly, switch off your phone and put it on again if the location is different from where you used to use your phone, or, Check the network settings and select automatic to see all the available network on the area pick from all the list and if none of these worked then the phone may need to be work on l.e to be fix.
Sep 01, 2009 | Nokia Cell Phones
Can't recognize wireless adaptor
RESTART YOUR COMPUTER, ON REBOOT, CLICK F10 WHEN YOUR CHANGE BOOT OPTIONS SCREEN COMES UP. YOU MUST PRESS F10 QUICKLY OR IT WILL LOAD WINDOWS AND YOU WILL HAVE TO RESTART AGAIN. ONCE YOU GET INTO THE BIOS SETUP UTILITY GO TO SYSTEM CONFIGURATION, SCROLL DOWN TO BOOT OPTIONS CLICK ENTER. GO DOWN TO INTERNAL NETWORK ADAPTER BOOT AND ENABLE IT. THEN GO TO SAVE AND EXIT. AFTER YOU RESTART YOUR COMPUTER, CHECK IF THE WIRELESS IS WORKING. IF LATER IT FAILS AGAIN, GO BACK INTO THE BIOS SETUP, IF THE ADAPTER IS STILL ENABLED, DO A DIAGNOSTIC TEST FROM THE BIOS UTILITY. IT WILL DO A QUICK TEST (IT IS FAST) THEN IT WILL DO A COMPREHENSIVE TEST, THIS WILL TAKE AWHILE UNTIL IT FINDS THE PROBLEM. BE PATIENT IT WILL FIX IT!!! THE COMPUTER SHOULD AUTOMATICALLY SHUTDOWN WHEN IT FINISHES. WHEN YOU TRY TO TURN YOUR COMPUTER BACK ON, IT MAY NOT COME ON THE 1ST TIME, THIS IS OK TOO. JUST KEEP PRESSING AND HOLDING THE POWER BUTTON UNTIL IT COMES ON AND STAYS ON. NOW WHEN YOUR COMPUTER LOADS WINDOWS YOU WILL SEE YOUR WIRELESS ADAPTER IS WORKING.
Jul 01, 2009 | Computers & Internet
Cisco SRX200 re-boots
- Updating the firmware of your router will do to fix the issue.
Mar 17, 2009 | Linksys 4-port Wirelss Router W/srx200...
No signal dropped calls and contact duplication
Was vacation in Hawaii? I think Humidity has gotten the best of your phone. If its a 3G phone call T-Mobile and see if their is an update for your phone.
Armymason
Feb 26, 2009 | T-Mobile Dash Smartphone
Motorola Mobility E815 Logo
93 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
