Home | GE | JE1860 1100 Watts Microwave Oven | Microwave - no heats - v...
GE JE1860 1100 Watts Microwave Oven
Problem for GE JE1860 1100 Watts Microwave Oven
Microwave - no heats - vibrating sound
By wwhinton on Oct 10, 2009
GE Microwave no longer heats. The familiar hum has been replaced with a harsh, vibrating sound. Everything else seems to be working.
Best Solution
posted on Oct 11, 2009
Very Helpful)
MicrowaveSvc
Rank: Guru  GE Kitchen Appliances  Expert
Rating: 89%, 5208 votes
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
(it may pass the checks and still be bad)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's under magnetron warranty, GE will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Useful for future. Sears already has it. Saved your links! Thanks. " - wwhinton
Popular Solutions for GE JE1860 1100 Watts Microwave
Questions and Unsolved Problems for GE JE1860 1100 Watts Microwave
Do you recommend GE JE1860 1100 Watts Microwave Oven?
Answer
Answer
After cooking some chicken in the oven for 10 minutes, I stopped it; then tried to cook for 3 more... (More)
Answer
It will keep turning the plate and lights on and humming, but not heating unless I set for minutes... (More)
Answer
Everything seems to be working and I have checked the power level but after 3 minutes of heating the... (More)
Answer
I have a JE1860 microwave that needs to be replaced (a nanny burnt the inside with popcorn. I have... (More)
Answer
the vent will go from high to low and to off, but when it says off it is still on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE JE1860 1100 Watts Microwave...:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
