Washing machine will not start washing when lid is lowered
What ever triggers the washing machine to wash after the filling with water when I lower the lid is not working. We used to have to let the lid drop a few times to trigger the wash cycle, but now it will not start the wash cycle at all.
  • Esteele Jan 04, 2008
    The machine is a Whirlpool top load. I need some help with how to troubleshoot the issue.
  • 328 Answers
Sounds to me like its either the washer timer or a lid switch. Both parts are relatively easy to replace yourself and I would lean toward the lid switch. Its important to check for any loose wires first around the lid switch. If you have anymore information or questions, dont hesitate to ask.
Posted on Jan 04, 2008
    Guru:
  • 1,894 Answers
Ya. not a big problem it seems. here it goes
when ever you close the lid the tip of lid touches a sensor which signals the control board to start the rinse cycle.
now these many days that sensor has been in dying stage. that is why you were often closing it to let the cycle open.
now that sensor has completely dies.
just replace the sensor at the point where the lid touches the opening.
after that enjoy washing.
  • dewan nafees ahmed Jan 04, 2008
    You may be able to check it. With the lid open and the dial set to
    agitate, try inserting a something PLASTIC like a stirrer or ballpoint
    pen cap into the slot where the lid cam engages the switch. It may be
    possible to manually turn the switch on with pressure UP, in the
    direction the cam would normally contact.
    if this is not working the lid switch is the problem. you will have to replace it.
    else it is the timer problem.. you will have to replace the timer.
    thank you sir.
  • dewan nafees ahmed Jan 09, 2008
    thank you sir.
Water runs out of it as soon as it starts going in
Water constantly running down the drain, and the washing machine repeatedly topping up with water, can be caused by faulty plumbing. The washing machine may get stuck on a wash, or rinse program, caught in a cycle of filling with water and losing it down the drain. When siphoning has started it can stick forever in this cycle.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine. It's exactly the same principal as siphoning beer out of a barrel into bottles or siphoning petrol from a tank. If the end of the drain hose is very low, then water can siphon out as soon as it enters the washing machine. If it's just slightly lower than it should be, then siphoning is usually triggered when the washing machine first pumps water out or even just occasionally.
This fault most often occurs when the washing machine has been moved out for cleaning or relocated in a new house etc. It can also occur if a drain hoses stand pipe isn't properly secured to the wall and falls over at an angle.
The drain hose should also not be pushed down too far down into the waste water pipe, which can cause siphoning just the same as if the stand pipe is too low. It needs to go just far enough in to prevent it falling out but it will fall out if not secured properly with a crook or tape. If the stand pipe that the drain hose is being pushed into is too low, then it may need raising. It could have fallen through the floor boards in which case you can gently raise it and secure it to the wall with proper brackets. If it was just installed too short, you can add a small extension piece.
Jan 09, 2011 | LG WD14311RD Front Load Washer / Dryer
Our washing machine fills with water, aggitates,
dont know what washer you have but follow hoses to find pump as it will be blocked,may be able to drain by lowering drain hose into bucket
Mar 16, 2010 | Washing Machines
Machine fills with water then will not start wash ( lid is closed
Check he lid switch and or replace it, should fix your problem.
Nov 25, 2009 | Kenmore Washing Machines
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
My washing machine fill up with water, but want
This could be a faulty saftey switch on the cover
Nov 08, 2009 | GE WBSR3140DW Top Load Washer
Top loader 600MB fills water but wont wash or spin.Water fills to right level and timer turns o.k.
Check the lid switch for proper operation. If the switch is bad or not being actuated by the lowered lid, it will block operation of the machine.
Oct 20, 2009 | Hoover HTC243 Top Load Washer
Washes but dosen't drain
you having an issue withthe lid switch not activating, either a bad lid switch, or the "arm that hits it simply not making connection and needs adjusting.. chances are you cant hear a "clicking" noise when the lid is lifted and lowered... if this is the case its a lid switch issue... for safety reasons, the machine is not recognising the door closed so wont enter a spin cycle. will hawever wash and fill
Jan 03, 2009 | Estate TAWS800JQ Top Load Washer
The washing machine will not fill with water.
this depends on the make of the washer / some whirlpool and kenmore will fill but if the lid switch is bad it will not advance to start washing ,,,, put the dial on spin and with it turned on close the lid and if it dont start spinning then your lid switch is your problem ,,,, can help better if i can have the make, model and serial off your washer.
Larry
Nov 24, 2008 | Washing Machines
Washing machine filling with water not finishing cycle
probably just a bad lid switch or best case loose hinge screws if lid switch is located on right side of lid opening try pressing it down with a pencil or small screw driver if works replaced lid switch by removing console screws under end caps or if newer modes switch located under rear hinge area remove console by pressing clips at lower edge each end of console ..remove brass colored clips on older model and pull cabinet or newer model switch is mounted to top of cabinet under console
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Open Questions:
Washing Machines Logo
185 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
