Question about Polaroid CAA-03040S Camcorder
Screen says Error
When i put the batteries in the camera about 3 seconds pass and the camera screen says "sensor error" i need help
    Problem Solver:
  • 6 Answers
Contact polaroid. You have a 1 year warrenty from date of purchace; also you should keep the receipt handy while calling them.
Posted on Feb 09, 2008
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Error 5 on Canon eos 350D
Well first of all you can try a full reset, Pull both batteries out -the normal one, and the date/time one. If your camera is older (>2 yrs), it may be time to replace that battery..... anyway Put a new one in, and then put in the freshly-charged main battery, that might clear the error. If further you have the same problem then something is causing the flash to stick. Press the button and pull gently on the flash. Post comments for more help or information needed.....
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Keeps showing on screen, "camera error # "
If this camera just show blue screen it means that the LCD or he mainboard of the camera is defective., is this error code display also a number., usually it will also display the error code number.
If you have this error code please call tech support toll free 1 800 235 6325 and send the camera for repair
Nov 13, 2009 | Kodak EasyShare P850 Digital Camera
The tape runs for 3 seconds then error message ''please re-insert cassette / on screen error code C:32:22 - head cleaner tape has the same effect
When I got this error I removed the battery for 10 seconds and then put it back in. Camera should come on automatically. I just did this to mine and it seems to work.
Oct 03, 2009 | Sony Video Cameras
Communication error?!
I'm betting you bought an aftermarket battery and not an original JVC battery. The error message you are getting is caused by the camcorder not being able to read the charge sensor in the battery. Some of the aftermarket batteries neglect to put that sensor in the battery, or have a sensor which does not match the OEM sensor in a factory battery. Try an original JVC battery. Is this solution answered your question bu sure to rate it. Thanks!
Oct 23, 2008 | JVC GR-D750 Mini DV Digital Camcorder
Canon A400
Having using standard LR6 batteries in a Canon before you will only get 3 or 4 pics max before it drains the batteries. You really need high power AA's like 2300mAH+ rechargeables for any good performance or Lithium AA's
Aug 28, 2008 | Canon PowerShot A400 Digital Camera
Error code on screen E:61:00
Try resetting your camera to factory defaults:
  • Turn off the camera.
  • Ensure the camera is not connected to an AC power adapter.
  • Remove the battery from the camera for 15 seconds.
  • Reinsert the battery.
  • Turn on the camera.
  • Apr 18, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
    Will not stay on, shutter does not close when camera is off
    noavatar_s.png By nonexpert_s.gif Sitsika
    Rank: Apprentice
    Rating: 0%, 0 votes
    HP put out an update which can be downloaded from their site, to correct this problem. They state it's a software problem in the camera itself.
    You might try powering the camera off, then restart it to see if that might help. With camera off press and hold the on switch until the logo appears, then immediately release it. Reopen the camera and follow the inquiry's which will come up on the screen.
    Watch the lower left hand of the screen and see if an error message pops up momentarily, The format would be "Error 108."
    You can also e-mail HP tech support and they will try to help you at no cost.
    Good luck...Sitsika
    Dec 17, 2007 | HP Photosmart 733 Digital Camera
    Polaroid CAA-03040S Camcorder Logo
    54 people viewed this question
    Top Polaroid Video Cameras Experts
    Eric Sutherland
    Rochell Cruz
    Tony Parsons
    Tony Parsons
    Are you a Polaroid Video Camera Expert? Answer questions, earn points and help others
