Question about Nintendo DS Lite Console
Touch screen hello, I have a touch screen problem. It doesn't work at all. It only works when I use the control pad. When I turn the power on. It goes directly to the main menu screen. Normally it asks me to touch the screen. Please help. Where can I take my system to get it fixed? Thanks!
  • 4 Answers
Contact Nintendo. as you didnt say if it was a DS or a DS lite
go to http://www.nintendo.com/consumer/systems/selectds.jsp
its Nintendos DS Customer Support.
Posted on Dec 25, 2007
Error message E6 F2
From investigation, I would open the control panel (make sure the power is turned off first!) Look for a ribbon cable that goes to the Touch Pad and Control pad module. It should be able to be removed from the control board. Pull out the ribbon cable, and put the ribbon cable back into the connector. Be careful with the cable as they can be broken easily. Once you have everything back together, turn the power back on and test the pad. If it still doesn't work, the control board may be bad.
Nov 05, 2013 | Whirlpool Gold Resource Saver GGE390LX 30"...
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Kitchenaid superba kgsc308lssc keypad not working
Hello Ron,
On that touch pad not working do any button at all work?? its not a uncommon thing for the touch pad to quit working,in some case its just a matter of making sure the plug on it has a good connection where it plugs into the control board. If certain button work while others don't its a sign that the control board itself is good and the problem lies within the touch pad and it would need to be replaced. It may possible as to clean the connection of the ribbon cable on the touch pad by using a pencil eraser and try cleaning the ends of the ribbon cable,again if that doesn't work the touch pad would need need to be replaced . On that model the touch pad is integrated onto the control console and the part number for it is 9782418CB just so ya know its pricey (over $200 )
Good luck,GENE
Oct 06, 2011 | KitchenAid KESC307 Electric Kitchen Range
I turned off the power prior to changing a bulb controlled by a Leviton true touch dimmer. Now, the touch functions no longer work. the light is stuck on bright (dimmer doesn't work) and I can only...
The switch has a protected memory and will go to the default setting in case of power failure or shut off. Make sure you swapped it with the same watt/type bulb. You can always shut off the power to the dimmer for a few min. and turn it back on to force a reset.
Sep 04, 2011 | Hammering
Continuous beeping with F7 fault code. What do i need to replace, the touch pad or controller?
Hello, Thank You for using FixYa. I will be helping you today.Turn off power unplug ribbon cable from touch pad to control turn power back on and if after an hour no error code replace touch membrane if you get a fault replace control (clock Erc)
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Jenn-Air Ovens
Touch pad does not operate. have uninstalled and reinstalled correct driver and PC device manager says device is working properly with no conflicting programs. generally, the pad did not really operate...
it is possible that the touch pad is disabled. Check control panel to actually confirm.
Since your touch pad is not operating, you will need an external mouse to perform this task.
Here is what you have to do to check if the touch pad is disabled.
Turn on your laptop, wait till it boots completely.
Click start,
Scroll to Control Panel select Control Panel.
Under control panel, (you will find a Mouse icon), click Mouse and a dialogue box will pop out.
On the dialogue box, click "Device settings".
Under device settings, you will find "Synaptics Touchpad..."
Highlight the "Synaptics Touchpad..." by clicking on it once, then click enable.
By now the mouse pad should be enabled. Apply the changes for it to take affect.
If the above doesn't solve the problem, try performing system. System restore can help to back date your computer to the time when the touch pad was working....
Go to Start > All programs > Accessories > System tools > System restore. Read and follow instructions.....
If the two solutions does not work, please let me so that I can further help you.
Yours sincerely.
Elect_Comp.
May 26, 2011 | HP G60-120US Laptop
My sony handycam DCR-HC26 is frozen on "clock set"
Hello i am hamid
I need a drive for Windows 7 Help me please
hamid.far12@yahoo.com
Jul 07, 2010 | Sony DCRHC26 MiniDV Digital Handycam...
My touch pad worked fine last night, but now it doesn't! Help!
well, first you should see if it needs charging. Then turn on the ds and touch the little ds on the bottom of the screen. Go to the calibrate or the thing that is on the right side of the person. Try thr test and dont stop it until its over. Try touching the screen again but if that doesnt work call nintendo which the number is in the manual or find it at www.nintendo.com. See if that works.
Dec 27, 2009 | Nintendo DS Lite Console
Htc locked touch screen mal functioning
Try mDesktop for remote control from your PC to unlock the phone.
Apr 10, 2009 | HTC Touch P3450 Smartphone
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Nintendo DS Lite Console Logo
89 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
