I plugged in the WII to my WS-65809 Mitsubishi projection tv, it worked for 1 hour and then the set turned off. At first the set got no power indicator at all. I unplugged it, and then turned it back on. Now the timer light goes on for about 10 seconds and then goes off. any suggestions?
There is a resistor by the high voltage transformer,it has low value and it opens for no reason,he is likely open and does not let the set stay on,if you are familiar with tv service you can replace it and while you are down there check for any over heated areas and resolder them specially the convergence IC.This resistor is located in the back edge of the chassis in the board in the right side and it might be hidden by a plastic casing that covers the high voltage transformer.If you are not too familiar with tv service you should seek the help of a servicer.Let Us know how it goes or if you need more information.
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
Hello, I have a 65" Misubishi HD1080 and when I plug it in the timer light flashes for a while and when it stops I try to turn it on and the light just starts flashing again but the tv never turns on.
