Question about Bosch Washing Machines
How to reset the error codes (F21) on Bosch Maxx 7?
See this url
http://experts-univers.com/mon-lave-linge-bosch-maxx-7-ne-fonctionne-plus.html
Posted on Apr 29, 2011
    New Friend:
I'm trying to do what you've said, but I can't press the rpm button.
Posted on Dec 21, 2015
Turn knop to clock 6 then press spin speed button and turn 7 clockwise same time. Keep five seconds and stop pressing spin button. Then turn clock 13 bakwords and wair. Then off. 5 year old maxx7. Motor brushes was gone so i change them. Only take motor off and you can change brushes easily.
Posted on Oct 14, 2014
  • Anonymous Mar 19, 2018
    Thanks, I also have a MAXX7, but needed to go from 6'oclock (spin) to 5'o clock (quick wash) and used the start stop button. So the trick. 1. Go to off. 2. Go to 6'oclock (spin) 3. Press start/pause 4. go to 5' oclock (quick cycle) 5. release start/pause. At this point the errors cleared. Good luck. You may need to fiddle a bit. I had to do this twice, unplugging the machine from mains between resets for 3 minutes to get it to remember. I also let it run the quick cycle before switching off.
2 Suggested Answers
SOURCE:
Daniel S
  • 4323 Answers
SOURCE: How to reset the code
Hi
F21 error in your Bosch washer relates to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 22, 2011
Our bosh Maxx 7 varioperfect washing machine buttons are not working Amd showing f:21 error
F21 error on this model of Bosch washing machine pertains to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely.
Nov 17, 2016 | Washing Machines
How to reset the error code F21 on a Bosch Avantixx 6
You can try the following steps:
1. Turn the washer knob to the 'off' or reset position 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button.
4. While holding it, turn the knob to the 7 o'clock position.
5. Continue holding the spin button for about 5 seconds.
6. Release the button.
7. Turn the knob to off.
When your turn it back on it should have cleared the error code.
Jul 21, 2016 | Bosch Washing Machines
How do i reset code F21 to a Bosch Maxx 7 washing maschine?
Turn knob to 12 o'clock position
turn to 6 o'clock position
press an hold the spin button
turn knob to 7 o'clock while still pressing the spin button
let go of the spin button after 5 seconds
turn the knob back to 12 o'clock
assuming you have repaired you're f21 motor issue it should behave its self
Mar 27, 2015 | Bosch Washing Machines
Hi Washing machine BOSCH Maxx 7. Displays error F 21. What's wrong - and what can we do ? sincerely,Jette
The F21 error code indicates that you have a problem with the washing machine's motor.
Have it checked out by competent electrician.
Feb 22, 2015 | Bosch Washing Machines
F21 what can I do? Please please
Hi
Daniel
Aug 04, 2011 | Bosch Logixx WAS2446 Front Load Washer
Bosch classixx 6 1400 machine stopped working during cycle f21 on display
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Release the button.
Nov 27, 2010 | Bosch Washing Machines
What is the error code f21 means on a bosh washing machine?
To reset it.
Whilst holding it, turn the knob to the 7 o'clock position.
Release the button.
Nov 27, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Bosch exxcel 1200 express washing machine not working, F63 flashing on display,are the brushes on the motor worn out?
I had F63 on Bosch washing machine (Maxx 7). I waited 5 days for a repairman and all he did was reset the washing machine processor, like this: 1. Turn the program knob to 6 o'clock 2. Hold the RPM button 3. While the RPM button is held, turn the program knob 1 click clockwise (to Rinse) 4. Release the RPM button.
This is similar to F21 which also happened to my machine. Apparently both errors are related to power surge/power cut.
Oct 25, 2010 | Washing Machines
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Washing Machines Logo
26,149 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
