Question about Frigidaire FEF336BC Electric Kitchen Range
Broken glass light cover...
Is it safe to operate the oven without the glass light bulb cover? It broke when I tried to replace the bulb.
  • 640 Answers
You should be able to use the unit without a problem,in between the panels where the light is theres insulation.you can try northernparts.com they may have a replacement cover for your unit.
Posted on Dec 26, 2007
The cover for the oven light has broke leaving the screw part inside cannot get it out.
If you mean the glass dome of the bulb has broken leaving only the metal bulb base, you will need a medium size long nose plier to grip the edge of the bulb base, you can then gently rotate counter clockwise to remove.
ENSURE THE APPLIANCE IS ISOLATED FROM THE MAINS SUPPLY BEFORE ATTEMPTING THIS !!! PULL THE PLUG !!!
Apr 21, 2018 | Microwave Ovens
Can I bake in my gas oven without the glass cover for the light bulb?
I would say yes. I took my cover off to change the bulb and never replaced. Works fine.
Sep 20, 2015 | Frigidaire FGB24S5A Gas Single Oven
Where is the light bulb in the main oven as I need to replace it
On my older Jenair, it is on the upper surface of the oven. It has a glass cover that would need to be removed to access the bulb.
Could be the switch or connections at the switch that is preventing the bulb from operating. Depending on age of oven and frequency of use of the light, oven bulbs last a long time. Mine is still good after 26 years!
May 07, 2015 | Ovens
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Replace bulb
oven bulbs are special bulbs only available from an oven service agent
although the ratings are the same , the glass used is actually pyrex glass as ordinary glass will not handle the oven temperatures
Dec 24, 2017 | Viking Professional VESO130 Dual Single...
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
Replace light
The instructions state:
1. Ensure the oven is disconnected from the electrical supply.
2. Turn the glass cover anticlockwise.
3. Remove the faulty bulb and replace with the new one.
4. Refit the glass cover.
5. Reconnect to the electrical supply.
Jan 09, 2014 | Zanussi ZBF360 Electric Single Oven
Cooktop light socket needs replacing, bulb broke in it. Socket needs replacing.
make sure the light is off, better yet turn off the breaker
take a potato a little larger than the socket, cut it to size, whatever.. jam it into the broken bulb (carefully), this will allow you to grip the broken bulb safely. turn counter clockwise and whats left of the bulb should unscrew out.. works VERY well
Feb 15, 2013 | Microwave Ovens
Frigidaire FEF336BC Electric Kitchen Range Logo
884 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
