Question about Philips 42FD9932 42 in. Plasma Television
Black and White Problem ????
I removed the television from the wall for painting. Layed it on its back for about 2 hours, then stood it up against the wall overnight. Hanging it up the next day and the screen was black and white.
  • 149 Answers
Are you using component imput is the only logic thing... connections good luck
Posted on Apr 09, 2008
Can you use ultra white paint as a primer on a wall before painting it?
Not recommended, especially if the ultra white paint is anything but "flat." Primer is designed specifically to adhere to other paints. Look into KILZ primer (if it is available where you are), as I have found it to provide excellent coverage for color changes.
May 08, 2015 | Tools & Hardware - Others
I have painted the wallpaper in my kitchen about three times about two years ago I used Dulux matt dark streaks have appeared on the outside walls condensation marks? the paint looks chalky do you think...
There are 2 types of paint I do not like, Behr and Dulux. Buy Benjamin Moore for best results. Painting wallpaper is not advised, if it is not adhered on well, you can have trouble. Streaks could be condensation, especially in a bathroom, a kitchen can also be damp because of boiling pots. Warm moist air condenses on a cool object. It could be the wall paper is losing adhesion. Check to see if the paper moves a bit when pressed. Remedy is remove the wall paper and repaint. Get all the glue off, scrape it after soaking the wall. Sand the wall, wash with TSP, rinse with clean water. If you don't do this, you will get a lousy paint job. You would be best to prime then top coat. Alternately get a paint that is self priming. In a moist area use Zinnser
Home Hardware Paint Dcor
Zinsser 1 gal Perma White Mold and Mildew Proof Satin Interior Paint 2...
Mar 02, 2015 | Miscellaneous
Oil from a reed diffuser spilled all down my bathroom wall on Benjamin Moore paint how can I remove the oil thT stained the painted wall
I would wipe it down with a degreaser like Simple Green, or paint thinner
The paint is ruin after cleaning it you will need to paint. You can prime the area with a oil base white primer in an spray can
Jul 23, 2014 | Tools & Hardware - Others
Only shows black and white
The problem must be with it connections you have done. Contact any service technician. Do not make any experiments. Remember; it's a plasma TV. Gopakumar Gopalan Google
Mar 12, 2014 | Fujitsu Siemens Plasmavision P55XHA30 55...
This is the second summer for my krystal clear salt water system (above ground intex pool). When the low salt light came on I cleaned the cell as directed but the light came back on. I shut it down and...
Did you check the salt level and was it between 2000 to 3000ppm?? These are the two causes for the low salt alarm.. Dirty scale buildup on the cell and low salt level.. Also, you may need to add a scale buildup preventer. hth makes a bottle called "cell saver" it works okay and prolongs my cell cleaning cycles...
Aug 10, 2011 | Intex Automatic Salt Water System for ...
Need to be able to disassemble an intermatich FD2HW - take the plate off the wall to paint the wall. Not sure if the timer buttom pops off or unscrews to remove it? Not like my other light switches which...
The knob pulls off.
Use small screwdriver to pry it up.
Really old FD and FF series timers, the knob has tiny set screw in end of knob.
I haven't seen one with set screw for years
Dec 25, 2010 | Intermatic FD2HW Energy Controls - In-Wall...
TV taken off wall mount and layed flat ( horizontal) for a few hours. When reinstalled only vertical lines appear? Audio OK
You will have to take it back down and make sure all of the wire connections are all tight inside.
Also you want to make sure nothing was over tightened when reinstalled causing any boards or anything to crack inside.
Remember there is high voltage inside.
I hope this helps, if not get back to us and we will farther try to help you.
Mar 15, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Remove them from painted walls.
go to napa or loure local car care place and get goop hand cleaner
Nov 24, 2009 | Toys
Philips 42FD9932 42 in. Plasma Television Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
