Question about Canon Elura 70 Mini DV Digital Camcorder
Card error cassette error
There was a cassette in camera, took out, now wont do back down. There is an SD card in. We we go to record, card error or cassette error.
  • Anonymous Feb 11, 2008
    removed cassette that was just used then a little later tried to re-install but the camera would not move the cassette down and instead ejected the cassette. battery is fully charged and all other functions have been working correctly
  • Anonymous Feb 23, 2008
    My elura is also telling me to eject the tape. I have sent it back once already and it worked ok for maybe 4 hours and then started doing it again. Is this a factoy defect on these things
A common fault, take it back to the shop!
Posted on Dec 25, 2007
I WANT TO RECORD VIDEOS ON SD CARD. BUT ONLY PHOTOS ARE GETTING STORED ON SD CARD. ALL VIDEOS ARE GETTING RECORDED ON CASSETTES. HOW TO CHANGE THE SETTING SO THAT VIDEOS ARE REOCRDED ON SD CARD???
As much as I know of this camcorder is not designed to store videos on your card. So keep to what it can do. the video is so bulky for this camera's card to contain anything of material. I think that's why it is not meant to do that.
Feb 10, 2011 | Panasonic NV-GS25 Mini DV Digital...
Formated sd card in laptop now card wont work in camera
once you format the sd card, the computer changes the management and sytem files and makes the sd card ready for use with the computer. so you should be getting an format error.it's recommended that you format the recording media using the device you intend to use it with.i this case, since your using a camera, format the sd card using the camera.check camera instruction manual for additional info where to pull up format option in the menu settings.hope this info helps.tnx:)
Apr 29, 2010 | Cameras
Sd card problem
did you try to get another card or it doesnt take that certain card
Jun 14, 2009 | Polaroid i835 Digital Camera
Camera won't record on SD card
SD cards have become the industry standard....but beware...there are SD cards NOT backward compatible...i.e.,some cams won't take 2GB or larger; then there is SDHC; SDHC(HD); RUNS FROM 512G thru 32GB HC/HD; ECT...check your cams manual for SD card compatibility.
Apr 27, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My camcorder will only record in 10 second intervals
There is a 10 second limit to the SD card recording. pretty useless, but that is how it somes from the factory
Apr 11, 2009 | Canon Optura 20 Mini DV Digital Camcorder
Camera says card write protected
I just figured it out- on my memory card there's a small "switch" on the left hand side that you can slide up and down. Make sure that this is up the top, not down towards where it says Lock. If it's down, this makes the card Write Protected.
Nov 27, 2008 | Canon EOS Rebel XSi Digital Camera
Card error
Just triple-check that you haven't accidentally locked any of the cards.
On an SD card, for example, there is a TINY little white switch on the side that write-protects the card.
Back in the day of audio cassettes, the tab was "felt" by a mechanical arm.. if the tab was present, it could record. If the tab was missing, it would not allow recording. I'm not sure if digital cameras still work like that or not? If so, it could be something like that in your memory slot. =-]
Aug 18, 2008 | Canon PowerShot S3 IS Digital Camera
Digital camcorder
This is an issue Canon has recognized with some of their models. I suggest you go to the Canon website and see if you can find your their - I believe they are doing an out-of-warranty repair for the affected models.
Dec 25, 2007 | Canon Elura 70 Mini DV Digital Camcorder
SD Memory Cards to record in MPEG2
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher. *Usable capacity will be less. The use of SD Memory Cards other than the ones mentioned above may result in the following error message: [This card cannot record in MPEG2 mode.]
Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
Aug 31, 2005 | Panasonic D-Snap SV-AV100 Digital Camera
Canon Elura 70 Mini DV Digital Camcorder Logo
325 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
