Check first drain hose at the back.
If that is fine, next step is disconnection appliance from power and reaching the drain pump.
Even if the pump is working there may still be a blockage in hose connected to pump.
Pump is accessed removing the small panel on the lower right side , in front of the appliance.
Be prepared to collect a lot of water with a pan when you undo the pump.
A blockage in pump is the most common cause for drain problem, however, if there is no problem on pump lines, problem with pressure switch/water level and timer board can also cause the washer not draining.
Accessing the drain pump and cleaning the hoses will probably fix the problem
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Tricity Bendix AW1000W Front
My 8 place Bendix dishwasher does not fill with water. It seems to go through the motions of washing...
(More)
My 8 place Bendix dishwasher does not fill with water. It seems to go through the motions of washing but has a burning smell and the contents are completely dry after the wash cycle. I do not know the model number, it is a slimline washer
