Tricity Bendix TM310W Electric Dryer
Problem for Tricity Bendix TM310W Electric Dryer
Tumble dryer spins, but doesn't heat up
By steve_kenzie on Oct 10, 2009
My Tricity Bendix tumble dryer spins, but doesn't heat up. What might cause this?
Best Solution
posted on Oct 10, 2009
Very Helpful)
mudstuffin45
Rank: Guru
Rating: 92%, 26 votes
You need an ohm meter to do needed checks. Unplug dryer from power,,, then look for sensors and locate the heat coils. Using the ohm meter, check each device by connecting meter to the posts ( your looking for an open curcuit) Note that when you touch the leads of the ohm meter together, the gage will move? This is closed condition, and if the needle did not move, this is called "open". When you find a sensor or heat coil that reads open, that part is bad.
Now make sure there is not a tripped breaker in the fuse panel of the house,,, because even though the dryer is 220 volt,,, 110 volt runs the tumble motor while the other 110 volt curcuit runs the heat side ( so one will work without the other)
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Tricity Bendix TM310W Electric
Questions and Unsolved Problems for Tricity Bendix TM310W Electric
Do you recommend Tricity Bendix TM310W Electric Dryer?
Answer
Answer
The tank full light is on but the tank is empty and the dryer wont run
Answer
Problem for Tricity Bendix TM310W Electric Dryer Light says tank full even though i have emptied it
Answer
Ive got a tricity bendix TM 310W Condenser tumble dryer that until this morning worked just fine,... (More)
Answer
lights all on but not working i realised the water storage was full emptyed it but not working now
Answer
tumble drier tumbles but no heat its an Indesit...is it the thermostat
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
