D-Link Express EtherNetwork DP-301P+ Print Server
Problem for D-Link Express EtherNetwork DP-301P+ Print Server
Printing throw terminal server
By DVORY on Dec 25, 2007
I configred correctly the print server and successed to print throw my local printer but as I connect to a far station using terminal services I do not see any printer.
1. the printer is the default printer.
2. the same driver allready installed on the server.
3. I tried to check mark the box in the RDP for printers with no luck.
PLS need Help
Solution #1
posted on Dec 30, 2007
Not Rated)
ACT1850
Rank: Guide
Rating: 92%, 10 votes
Are you remoting into your server from a differnet location than where the server is? I need to know th physical location of the printer to the server. If the printer is connected to the server there is a problem with the driver. if the printer is connected to your local PC you will need to click on the options button in remote access and tell it you want to use local resorceses. If the server / Printer / PC are in the same location do not access the server thru terminal services, set it up as a client server.
Was this helpful?
Yes
No
Popular Solutions for D-Link Express EtherNetwork
Questions and Unsolved Problems for D-Link Express EtherNetwork
Do you recommend D-Link Express EtherNetwork DP-301P+ Print Server?
Answer
Answer
no puedo imprimir deja la impresion pendiente por hacer
Answer
i connect with my print server then ping with my all system Reply but if i give print command in any... (More)
Answer
I have two printers, Pansonic both, KX-P1624 and KX-P2123 (I think), both printers will not print to... (More)
Answer
Hi, Appreciate if anyone could help me on this printer configuration for D-link DP-310P by Unix?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For D-Link Express EtherNetwork...:
Top Print Server Experts
Rank: Guru Guru
Solutions: 3668
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Print Server Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
