Lexmark Z640 InkJet Printer
Problem for Lexmark Z640 InkJet Printer
I have installed my Z640 printer to my new laptop.
By ih_emc on Oct 10, 2009
I have installed my Z640 printer to my new laptop. It is telling me that the printer is my default printer and ready. However when I go toproperties and click print test page,it tells me that the page has been set to the printer, then 'Communication Not Available'. Any ideas please. I have uninstalled and reinstalled. Restarted computer, onplugged and reconnected printer power and usb all to no availe. Help please. Ian Hilson
Solution #1
posted on Oct 10, 2009
Not Rated)
bob_computer
Rank: Guru  Computers & Networking  Expert
Rating: 87%, 1482 votes
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Was this helpful?
Yes
No
Solution #2
Not Rated)
yash khatri
Rank: Master
Rating: 75%, 110 votes
please you aply a comand by control p . when so the dailokebox in go the menu in paper to select and so the apaer size in letter other legel and a4 size but who to use the paper size is select and aply ok
and use printer.
Was this helpful?
Yes
No
Popular Solutions for Lexmark Z640 InkJet Printer
Questions and Unsolved Problems for Lexmark Z640 InkJet Printer
Do you recommend Lexmark Z640 InkJet Printer?
Answer
Answer
I have a lexmark z640 but i hav lost the disk 4 it wot is the best way of connecting it 2 my laptop... (More)
Answer
I have had a new harddrive on my computer and I cannot re-install my lexmark z640 printer it is... (More)
Answer
unable to install my printer to my laptop windows 7 have tried with disc and downloading from... (More)
Answer
has ink and does not print printer was printing last time it was used,but does not respond when... (More)
Answer
i have recently purchased a new laptop, it's a dell and my lexmarkZ640 is not compatible to this... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
