Expert
- Posted on Oct 10, 2009
Re: all the connections work the ps3 comes on but then...
You may have messed up the Screen-Settings, to solve this try this.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
- Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
- Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
- Continue to hold the Power button and after about another 5 seconds
you will hear a third beep and the system will power off (Power light
is red).
Step 3:
- Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
- Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
you will hear a quick double beep. At that point release the Power
button. If you succeeded in activating Safe Mode, you will see a
message on the screen saying, "Connect the controller using a USB cable
and then press the PS button."
- Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
- Then you will see the Safe Mode menu.
Step 4: We recommending performing the safe mode
options in the following order until one of the options works for you.
If one of the options work, do not continue onto the other options.
- Restore Default Settings
- Restore File System
- Rebuild Database
- Restore PS3 System (This will wipe your harddrive, so remember to backup savegames.)
