Question about Asko T701 Electric Dryer
Asko dryer filter assembly
The filter assembly has two strips, one on each side. One is coming off and I need to attach it or replace it. Is there replacements? Or should I just try to glue it back? Is the type of glue important due to temperature problems?
Clarence Holt
E-mail delphii@aol.com
  • 126 Answers
It's just to press them on again. No big deal.
Posted on Jan 29, 2008
Removing the Idler Pulley Assembly
Whirlpool manufactured brands including Admiral, Estate, Inglis, Kenmore, KitchenAid, Roper, Maytag, Crosley, Jenn-Air, Hardwick, Magic Chef, Amana, Glenwood, and Caloric. All of these front loader conventional electric dryers are very similar. The idler pulley attaches by a snap in spring assembly.
26031432-cqk4auvkq54bteptus3ub0nf-1-0.jpg The spring assembly is purchased as one part with the idler wheel attached. If the make of your dryer is different than the above please provide additional information.
Dec 31, 2015 | Haier HLP140E Electric Portable Dryer
Replacing Drum paddle lifter for Asko washing machine?
BIG JOB !! The machine will have to be fully stripped down as the only access to the paddle is by removal of the spin bowl itself from the machine. The paddles usually are held on at the front and along the sides by moulded clips that slide into the tub and are secured at 1 end by a set screw. If I remember correctly, the entire bowl assembly is removed through the front of the machine. The top and front have to be taken off to do this. Its a huge job, it may pay to obtain the services of someone who has done this before.
Jan 02, 2015 | Asko Washing Machines
ASko dryer T761 goes bump bump bump when starting. sometimes we can wiggle drum around and get it to stop. Help!
I believe asko says this is normal at start up and should stop after the drum has been spinning for a bit.
Jun 21, 2011 | Asko T761 Electric Dryer
Asko 7005 dryer, start capcitor is cracked and has hard goo coming out the side, dryer wouldn't start and stay running, now it won't start at all. Could the capacitor be the problem or do you think...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 17, 2011 | Asko T781 Electric Dryer
I need a power plug for my asko 7305 dryer and can not find one anywhere
Assuming that you need a 220V connector, they can be purchased at home Depot. They are generally made with about three feet of cable attached. you will have to take the back plate off of the dryer and attach the three leads to the proper termination.
Jan 23, 2011 | Asko Dryers
F2 error message after dishwasher backed up when draining. Asko brand.
Hi
Thanks for using FixYa. Error F2 in your Asko Dishwasher means high water level. This error occurs due to plugged/bad water pump and/or a bad inlet valve. If the water pump and/or water inlet valve are bad it should be replaced to resolve this issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Dishwashers
Ive rinsed the bottom filter as advised and dryer still shuts off
also wash the door filter,it may need to be serviced
May 15, 2010 | Asko T701 Electric Dryer
My ASKO T702C dryer just stopped working. It starts but after 5 mins it just turns off. Any suggestions?
Try opening the bottom vent panel and pulling out the filter box (there are directions and handles)... hold the filter under running hot water for a while and you should see all this nasty stuff come out. Worked for me!
Jun 11, 2009 | Asko T711 Electric Dryer
My Asko dryer shut off and my clothes are still wet. It won't start and the light on the pannel will not come on. I know I probably have lint in the system that escaped the lint trap or maybe something...
YOUR DRYER Has a fuse in it look for it probably somewhere close to where the main power comes in at. if it's good check the heat relay contactor assembly. www.repairclinic.com has the model you have and it may even be as simple as the door switch
Apr 09, 2009 | Asko T701 Electric Dryer
Asko Dryer model T-701
you need to replace the motor you can replace the rear half of the motor but you can only buy a complete motor.this isnt a common problem but i have had it before.it broke because you need to grease the pin every 5 years or so.
Oct 24, 2008 | Asko T711 Electric Dryer
Asko T701 Electric Dryer Logo
60 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
