wen i switch on my e260,it turns on but doesnt shows the menu screen,only the blank showing sandisk,then slowly it fades,this repeats .is it any firmware issue?or display probwen i switch on my e260,it turns on but doesnt shows the menu screen,only the blank showing sandisk,then slowly it fades,this repeats .is it any firmware issue?or display prob
AnonymousDec 29, 2007
Same problem. Holdiong the poer and play buttons did not change anything.
ISame problem. Holdiong the poer and play buttons did not change anything.
I
AnonymousJul 03, 2008
I have the same problem... i put it in recovery mode and i tok out the battery and it still keeps on doing the same thingI have the same problem... i put it in recovery mode and i tok out the battery and it still keeps on doing the same thing
You can't post conmments that contain an email address.
When you say the screen goes black even after disconnecting the device from computer it could be an issue with the firmware. It might need to have updated firmware. To get the updated firmware please go www.sandisk.com.
Where you can get the latest firmware for your model. *** Make sure when you update the firmware keep the device in MSC mode.
Here is the link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306 Kindly revert for further clarifications....
For the non-deletable files try:
http://forums.sandisk.com/sansa/board/message?board.id=e200&message.id=26888&query.id=215455#M26888
http://forums.sandisk.com/sansa/board/message?board.id=e200&message.id=24445&query.id=215455#M24445
http://forums.sandisk.com/sansa/board/message?board.id=e200&message.id=2824&query.id=215455#M2824
For the Display:
http://forums.sandisk.com/sansa/board/message?board.id=e200&message.id=25895&query.id=215591#M25895
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=16113&view=by_date_ascending&page=1
I just got an e260 today and had the same problem. When I originally turned it on the Hold was in the 'locked' position. From there on out the screen has been black. When it was plugged in nothing happened either.
The Solution? Hold the power button for about 20 or so seconds. The manual doesn't tell you about it, but that's how you completely shut the sansa down altogether. Yes, the manual says it's also a reset button but it isn't mentioned how you actually use it.
Once you hold that button down long enough it should completely shut down and restart.
I
