Question about E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
New power supply problem
I recently installed an new power supply on my emachines comp. and it powers up, but then turns off after about a minute. everything is hooked up, but I'm getting nothing on the monitor. Any ideas?
  • johng2008 Dec 26, 2007
    i see a red light on the mother board
    Master:
    Sergeant:
  • 482 Answers
Try to run it with out the memory and see if you have the right kind, put one stick in and try that, if still does not work, then you must have a short on the motherboard. I would replace that. most of the time the power box goes out it shorts the motherboard out too. if a green light is on, the power box is good and the motherboard is out. Farren
Posted on Dec 26, 2007
  • farren wadley
    farren wadley Dec 26, 2007
    red, green same thing
I NEED TO KNOW HOW TO CONNECT THE POWER SUPPLY FOR AN EMACHINES T1120 COMPUTER. CANNOT FIND A SCHEMATICS DIAGRAM ANYWHERE.
After reading an article about Emachines awhile back, I found out the reason you can't find the schematic- it isn't available, as some motherboards are made specifically for Emachines and therefore not distributed, as they might normally be, but again, others are, but you have to identify them and go through another source to get them- Emachines, appartantly, will not supply them. All is not lost, however...all motherboards have, basically, the same hookups and connectors for the power supplies, hard drives, etc.- they are standard. I found a web blog that explains the power switch, reset, and power led, which will help. Here it is: http://www.computing.net/answers/hardware/emachine-power-sitch-wiring/56545.html
This site will explain about the 24 pin connector from the power supply
http://www.tomshardware.com/forum/53750-7-installation-manual-rs480m-w3400-emachine-motherboard
If you google "motherboard wiring" you will find sites that have illustrations of the motherboard, and explain which connectors go to which sockets, and how to identify them.
With a little patience and determination, you should be able to hook everything up from the various blogs on the net. Hope this helps.
Apr 17, 2010 | E-Machines eMachines Desktop PC
Power suply the computer wont turn on
the smos of the comp might have gone bad
Feb 07, 2010 | E-Machines eMachines Desktop PC
Computer won't boot up.
If you don't hear anything on bootup then it is most likely the power supply and you can purchase one from your local Best Buy Comp USA type store. It is very easy to replace if you have repair/troubleshooting skills. I can elaborate if you want to give it a try but it sounds like the power supply that is bad.
Hope this helps,
TankMurdock
Apr 24, 2009 | eMachines T3406 PC Desktop
Not powering up .supply fine
remove your cmos / bios battery for 2 0r 3 minutes, reinsert it n turn on yor comp.
Apr 09, 2009 | E-Machines eMachines Desktop PC
Computer worked fine, unhooked it to hook up a new one, decided to hook the emachine back up to play games on, got it hooked up but it won't come on now. everything is hooked up right, i opened it up and...
make sure you hook everything with a little force especially the memory until it snaps back into place. same goes for all the cards. care should be give to the cpu, nice and easy. make sure your power supply is potential enough or has not gone bad. The MB can give a green light but there could be too little energy for the whole system.
Mar 27, 2009 | E-Machines Emachine T5026 power supply **...
One of the reasons that this could be is that the power supply doesn't have enough power to power everything. Trying exchanging it for another one that has more watts. If this is an exact replacement as far as the wattage goes, then your problem may lie else where, and you may want to take it to a reputable local computer repair shop for further inspection.
Aug 04, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
T2085 will not turn on
it does sound like a power supply. you can pick one up for around 80 bucks retail. they aren't that hard to install. 2 plugs on the mobo and one for each drive you have installed. all you do is unscrew the current power supply (4 screws on the back), then unplug all wires connecting the power supply to the components. then take out the old power supply and work in reverse with the new power supply.
if the computer doesn't work after that, it is possible that you need a new mother board. in that case, personally i would return the power supply and start looking for another computer.
but hopefully it is just the power supply.
Agent 10708
May 29, 2008 | E-Machines eMachines Desktop PC
Comp won't power on
Hi KlubeT,
I would suggest replacing the PSU (Power Supply Unit).
Gerry
Jan 31, 2008 | Dell OptiPlex GX270 PC Desktop
E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply Logo
87 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
