FixYa.com
Tags:
Panasonic NV-DS60 Mini DV Digital Camcorder
FLASHING ICON WONT RECORD. (by 3 users)
posted by Johntbissett on Dec 25, 2007
hi guys Merry Christmas,
I have a Panasonic NV-DS60B when I try to record the icon for a tape with a for a back slash through it appears witha double continuious bleep. I have tried a different tape, I have checked to make sure the save tape on the actual tape is at the correct position and recharged the battery. Any help would be most appreciated.
John
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Mar 23, 2008
Red flashing icon showing cassette cant get rid tried everything
Got the same problem cant get rid of red flashing icon of cassette tried everything, going bonkers
Clarification Request
by apinan, posted on Jun 16, 2008
thanks man did what you said and perfect, all working well
thanks
Best Solution
posted on May 16, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Cannot believe it FANTSTIC worked a nice treat nice thanks
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 21, 2008
FixYa! (100)
PanaReparMan
Rank:Master Master
Rating: 94%, 22 votes
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Can you Help with these Camcorders problems?
power problem
when conecting the power... Answer This...
where can i get replacement...
Hi, We have lost the leads that... Answer This...
ntsc/pal
how can i get this system to... Answer This...
panasonic mini dv palmcorder...
i have no software and my vista... Answer This...
Colour Viewfinder
The colour veiwfinder is... Answer This...
Repair Service
Find Camcorder Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
