Question about GoVideo Go Video DVD/VCR Combo
Installation How do I get the set up guide to appear on my tv
  • Anonymous Dec 29, 2007
    display screen only says hi wait
Jignbjiigjiujgtgijerojgiojhgiunibuhigubhitiubiutrbjnirtn
Posted on Dec 27, 2007
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
Clock will not set. Channel Guide will not
The TV Guide On Screen guide will not appear if you connect the unit to your television using composite or S-Video cables and the progressive scan option is selected.
Jul 24, 2010 | Sony DHG-HDD500 400-Hours Video Recorder
I would like the remote control code for a Nu Tec nue3201 tv Please?
I don't know if this helps you,but it may help someone, if you set the lock on this model and forget the four digit code enter 8034 on your remote doing this will switch the tv off, turn your tv back on, after your tv is on you will see the first time installation guide, select your language retune your tv, the code will reset back to 0000. In the book it says this password cannot be reset, it also says the first time(and only the first time) you turn on your tv set, you see an installation guide. how wrong they are, hope this helps.
Jun 25, 2010 | Televison & Video
I can't turn off subtitles on toshiba lcd flat screen
If everything else fails, reset your TV to its default settings via the INSTALLATION menu.
From the OP guide:
To reset all settings and channels to their factory
default values:
1 Press MENU and open the Setup menu.
2 Highlight Installation and press ENTER. A new set of
Installation menu icons will appear.
3 Open the System Status menu, highlight System
Information, and press ENTER.
4 Press to scroll through the menu bar to select
Factory Defaults.
5 Enter your PIN code (or 0000 if no PIN code has been set).
6 Highlight Yes and press ENTER. The TV will turn off
automatically after a few seconds. After the TV turns off,
Apr 08, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Cannot remove tv guide banner from Sony bravia 52'
Click on the display button (upper left corner) as a short term fix - it will turn it off immediately - not sure of how to permanently solve this though.
Apr 06, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Cant use all cable channels
Go to SET UP TV, press yes for the following question. SET UP GUIDE PLUS. This will take you to another GUIDE PLUS SET UP SCREEN. Answer the questions as they appear. The important question is going to be. DO YOU HAVE CABLE? Answer yes to this questions. Answer the rest of the questions as they appear. Then go back to MAIN MENU, select channel, then select auto channel search. This will find all channels that are offered by your cable package.
Jun 08, 2008 | Proscan PS32500 32" TV
Guide pop up
Maybe there is a setting for the guide in the main MENU settings to adjust when the TV GUIDE displays? Or just turn it off completely? Pretty basic answers, I know, sorry...lol : )
Nov 08, 2007 | RCA F36648 36" TV
Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
GoVideo Go Video DVD/VCR Combo Logo
27 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
