Question about KitchenAid Superba KSBS23IN Side by Side Refrigerator
Drawer installation I took my refrigerator drawers out for cleaning and can't figure out how to get them back in! can't get the drawers to sit under the shelves properly
zeusfaber
  • 247 Answers
SOURCE: fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
Posted on May 16, 2007
  • 112 Answers
SOURCE: ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Posted on Oct 18, 2008
  • 8 Answers
SOURCE: water leaking in refrigerator on shelves, drawers, and under draw
I had the same thing. And like the above solution I had to thaw everything out and melt the ice in the drain hole. This is about the fourth or fifth time this has had to be done. This last time I put a coat hanger down in the drain(about 4 inches) and hooked it around the heating element. This allows heat to transfer down the hanger and keep the drain clear. So far so good.
Posted on May 19, 2009
  • 82 Answers
SOURCE: Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
Posted on Jun 19, 2009
SOURCE: Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Posted on Aug 02, 2009
I cant get the cool select pantry drawer back in
I just had the same problem. The drawer was removed for cleaning and we could not get it back in; it would slide in with about 3 inches not able to go in. Took everything out that we could and still could not get it to go back in all the way. Finally started looking closer at the metal rails and the sides of the drawer and realized there is a tab on each side that needs to be inserted in the the corresponding hole on the metal rail. With the drawer out, pull the rails all the way out; place the side rails of the drawer on the metal side rails and line up the tabs with the holes and insert. Your drawer should now slide in correctly.
Dec 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
Took our deli drawer to clean. Can't reassemble. Help
If it's the deli drawer from the bottom of you refer and you took the entire assembly out at once you will know because it all came apart when you started cleaning it. If it's got two drawers then you now have a piece of glass a frame with legs on it and two drawers. So open the refer all the way, look at the back and the sides where you removed it from, you'll see some groves or ridges or little nubs take the frame by its self and fit it into those places you see, then take the drawers one at a time ( usually the one closest to the door hinge is best to start) and slide them back into place. take your time because like a dresser drawer there is a notch that you will have to work with that's designed to keep you from pulling it completely out when you open it. then place the glass into the frame on top and your done.
Oct 02, 2012 | KitchenAid Refrigerators
Took freezer drawer out and cant get it back in
Lift the front of the drawer while sitting it on the runners push it back and let it run naturally into the freezer
Apr 22, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
How do I clean around the rim of the refrigerator drawers?
Samsung draws are removable, but they are a pain and have to be pulled out, then lift up which allows you to bet the nylon wheel guide to dip under stops, and sometimes takes a little force taking out, and putting back in.
CERACOAT-NANOTECH.com
Feb 22, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
Can't reinstall meat drawer after cleaning
I think you'll have to move the fridge till you have the clearance to open the door all the way. Those drawers have to go straight in.
Mar 11, 2010 | Amana ABB1927DE Bottom Freezer...
How to completely clean the Crisper drawer
I don't know if you've already figured out how to remove the front panel on your refrigerator crisper bin, but here it is. Once the drawer is removed, pull back those clips on the top left & right of the front of the drawer.Just hold the side and pull back at the same time, then you can remove it. Once both side have been released you should be able to remove the clear plastic front and clean both pieces. I hope that is clear enough. Best of luck, unless of course you've already discovered the answer yourself.
Feb 21, 2010 | KitchenAid Refrigerators
I can't get the crispers and shelf back in after cleaning.
The bar goes into slots right above the drawers and under the shelf above the drawers. It's not obvious to see at first. It's at the very front of the shelf. You have to slide one end of the bar in first then the other side. The bar sticks out a little on each side so it can sit in the groves on the side walls of the fridge. For the longest we tried to put it underneath the drawers even though we knew it wasn't right. Hope this helps. The Whirlpool website can give you a parts manual if you enter the model number.
Jan 24, 2010 | Refrigerators
Aug 02, 2009 | Refrigerators
KitchenAid Superba KSBS23IN Side by Side Refrigerator Logo
19 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
