Home | Whirlwind | -Air Cooler with Heater and Humidifier, FH-... | My ac unit works spo...
Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner
Problem for Whirlwind -Air Cooler with Heater and Humidifier, FH-778...
My ac unit works sporadically. Today it cooled
By natasha74 on Oct 10, 2009
My ac unit works sporadically. Today it cooled perfectly all day until 11 pm then it stops cooling and the house goes up to 81. I shut unit off and then it starts to cool again. what do you think is the problem
Solution #1
posted on Oct 10, 2009
Not Rated)
meBNme
Rank: Guru
Rating: 92%, 177 votes
First check your filters to make sure they are clean and you have proper airflow.
If they are clean, then you either have low refridgerant or dirty coils.
The outside coils can easily be cleaned by disconnecting power to the unit, then using a water hose to spray off the dirt, grass, etc.
The inside coild can be very difficult to get to on some units and require a special evaporator coil cleaner. As for adding refridgerant, the Law requires one to be certified for purchasing or working with refridgerant so you may need to call a service tech for that. Expect a bill from $100 to $225 for a typical system recharge depending on how low it is and which company you call.
Was this helpful?
Yes
No
Popular Solutions for Whirlwind -Air Cooler with
Questions and Unsolved Problems for Whirlwind -Air Cooler with
Do you recommend Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner?
Answer
Answer
Just missing the piece that holds the vent in the window for an Everstar portable a/c. Is it... (More)
Answer
Installed a new Hunter thermostat a few weeks ago. All was cool (pun intended) until yesterday when... (More)
Answer
MPMI-10CR-BB6 DONT WORK THE AC DOES NOT TURN ON AND WHEN ITS PLUGGED ALL THE LIGHTS ARE ON, WHY ITS... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlwind -Air Cooler with...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
