Dell Motherboard
Problem for Dell (E210882) Motherboard
No disply of my motherboard plzz help mee.
By danushka on Oct 10, 2009
intel E 210882 motherboard
Clarification Request
Posted by mudstuffin45 on Oct 10, 2009
I may be able to help you out,,, but more information is needed. Exactly what is the problem? What is the computer doing (or not doing)? Try removing the Memory cards and unplugin the CD-Rom and start to see if you get a display or beep or anything. Come back here with a clarified version of your problem.
Solution #1
posted on Oct 10, 2009
Not Rated)
cyberdyers
Rank: Guru
Rating: 86%, 162 votes
Good day sir/maam, hi, if your motherboard wont turn on, you need to make sure that these 5 things are in good order. (By the way, disconnect everything except these listed 5.)
  1. (PC is on) Your power supply, make sure that the exhaust fan is spinning as you turn it on.
  2. (PC is off) Your memory module, (ddr1 or ddr2) clean the contacts using an eraser(pencil) the gold plate contacts and a clean brush your motherboard memory slot.
  3. connect the casing's pc speaker on the motherboard.
  4. connect a video card, make sure its good. If you are using the motherboard's VGA, dont connect a video card. Temporarily reset the CMOS, use or locate cmos battery jumper setting. usually its 1&2 set the jumper to 2&3, then back to 1&2. connect a good monitor.
  5. Connect a keyboard.
Now power on your PC, check your Keyboard, you should see two sets of lights: first set (NUM LOCK + CAPS LOCK + SCROLL LOCK) then a few seconds the second set (NUM LOCK only). at this point you should hear a beep from the PC speaker.
If not, you may hear 1 long and 3 short beeps. bad video card. OR continous beeps, bad motherboard.
If you did not hear anything, do it all over again several times.
Still not working? replace your motherboard, its bad.
hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (E210882) Motherboard?
Answer
Answer
dell rev.aoo aa a85538-702 cant power up need terminal diagram
Answer
my optiplex gx240 suddenly wont hold bios settings. changed the board battery...no joy. confused!
Answer
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,... (More)
Answer
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard... (More)
Answer
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in , TX
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
