Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile Side by Side (Not Stainless)
We are having water build up in the bottom of the freeze. We've disconnected the water supply but still having water which builds up, then freezes and starts puddling on the floor.
Can't find a pan to empty and the drain tube appears to be clean.
Any suggestions would be greatly appreciated.
Thanks
  • Anonymous Dec 26, 2007
    the freezer of my side by side is still forming ice on it s bottom. I defrosted it, for more than 24 hours, bur the problem is still there. What can I do?
    Greetings Annica
    Scholar:
  • 146 Answers
Remove the panel in back of the freezer compartment and clean your defrost drain. It is plugged and overflowing when it goes into defrost. You will see it when you remove the panel. It is probably frozen over so take the ice out of it then run a flexable wire down into the line (nothing to hard or you may pierce or pop the line off) to clean out the drain hose also. Then pour some water into the drain trough (about a cup) making sure it flows freely out. Then remove the front grill (sometimes called a kick panel) at the bottom front of the unit and pull your defrost pan out and check if it has water in it. That will solve your problem.
Posted on Dec 27, 2007
Can someone tell me how to find the pan?
Posted on Jan 06, 2008
Why is water in bottom of freezer
there are 3 problems I've come across with water leaks on this model. if there is ice build up on the back of the freeze it could be a drain problem or if its around the ice maker it could be that the supply tube is too long. also watch out if you push the unit too far back against the wall the gray water supply line could snap off ( replaced 6 of these)
Jul 31, 2014 | Whirlpool Freezers
Water in bottom freezer
Sounds like possible defrost drain. Water builds up over time. Need to pull evap cover and see if ice is build up in tray. If so defrost drain, should fix issue
Aug 24, 2012 | Maytag MBF2258XEW
There is an ice build-up underneath the humidity control drawers and the food in the drawers is freezing. It is a model RB 215 LABB. We have adjusted the temperatures of both the freezer and the fridge,...
The problem isn't the humidity control or temperature control. When the refrigerator automatically defrosts it goes through a cycle of heating and melting the ice build-up then drains this water to a tray at the bottom of the refrigerator (underneath). The drain tube that lets this water flow down to the bottom tray freezes so the ice begins to build inside the refrigerator section.
The solution to this is to defrost the tube so water can flow again. There are heating coils in the freezer section behind the plastic in the back that you must remove and defrost.
This is an inherent problem with a lot of refrigerator/freezers. You should probably have your refrigerator serviced and to check the heating capability of the coils to keep this tube from freezing. Otherwise put this on your monthly schedule of manually defrosting.
Sep 23, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
I have an amana side by side refrigerator. The ice is building up
There is a drain hole under all of that ice that got clogged at some point and it started building up ice in that area.  The water that is freezing is coming from the defrost cycle which melts all of the ice buildup on the evaporator coil.  First melt the ice.  Then unclog the drain hole.  The drain goes to a tray in back near the compressor, where the heat from the compressor evaporates the water.
Oct 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
Sep 16, 2009 | Woods Upright Freezer MU07W
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Top of the freezer will freeze but bottom want
Could be same as problem I just fixed.
Remove back panel inside freezer and
1. check fan operation
2. check for ice/water at bottom of the hidden section. There should be a drain hole, which may be blocked by ice. Fix by turning off and pouring boiling water in there until blockage is fixed
See http://www.fixya.com/support/t1507330-ice_collects_in_bottom_freezer
Dec 26, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
What causes ice build up on the bottom of a freezer?
your drain is probably plugged so when the fridge goes on defrost the water has nowhere to go.After the defrost cycle when the frige starts to freeze again the water freezes up causing ice build up
Dec 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
GE Bottom refrigerator/MOdel GS18LCRABB
I can only wonder if the drain tube has been cleaned out to make sure water flows into the pan .Also make sure it is fully defrosted and left over water will freeze quick.
Eeggman
Feb 18, 2008 | GE GDS20KBS Bottom Freezer Refrigerator
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
132 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
