No sir they will not interchange. i worked at a transmission shop for 7 years. the inline 6 has a 500 trans in it and the v8 has a 518 trans in it. the bellhousings are different.
I just bought after market headlight assembly units for my 1995 jeep grand Cherokee limited. The ball won't stay in the plastic piece. Won't snap in like the old one did. What do I do?
Use white paint, chalk or a scribe to mark the relationship of the front U joint to the front diferential pinion yoke. Mark the relationship of the rear U joint flange to the transfer case companion flange. Unbolt the front end of the drive shaft from the pinion yoke and the rear end from the transfer case companion flange and remove the drive shaft from the vehicle.
hope thei info helps.
sammyc47
Check with the junkyard where you got the pump...you may need to change the pump bracket with the pump, or use a different pump. You don't have a separate tensioner the pump is on a slide mount and is the tensioner (why the parts guy is a parts guy not a tech).
