Question about Toshiba 46HM95 46" HDTV
Red and green colors won't allign....
This is for a TOSHIBA 49". Red and green colors won' line up on left side of screen, yet all colors line up perfectly on right side of screen. Anyone experience this problem. Is their a resolution other than shooting set with BAZOKA?
  • 137 Answers
There is one way. Get way to go in to service menu and set conversions manualy. Remember to save. Tv will be ok
Posted on Dec 25, 2007
Right side of screen blurry with lines-TH-42PX75U
Check the site linked below, and compare the screen shots. It has many kind of defective screen-shots to plasma displays. Compare them to that of yours, and make sure about the faulty board or others. http://electronicshelponline.blogspot.com/
May 20, 2013 | Panasonic Televison & Video
I Have a major convergence problem. It is a 55 inch Toshiba ColorStream Projection TV(tp55h95). It was fine until we moved it into the other room, and now it's like the color is bending at both sides of...
Color arching.... Ahhh Yeah they eventually do that after a few years. Good news is all you need is a screw driver and some of your time and patience.
The color gun is a small box with 3 screws on it. (Blue, Red and Green. Turning the screws (Slightly) on the gun will get rid of the color arching. I had blue arching on a sony 65" Rear projection a year later it was red arching if you leave it long enough it will be arching and in and out flashing of solid color. Whole mind trip you don't want to venture on.......
The box on my sony was in the very front of the tv. I removed the front speaker panels and accessed it very easily. The hardest part is getting the front panel off. Yours may be in the back.
Best regards and Semper Fi...
Aug 06, 2010 | Toshiba TP55H95 55" Rear Projection...
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Jan 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
48 inch toshiba with color alingment problem
Hello:
Thanks for this forum.
I have a Toshiba 48" rear projection TV which started to show red and green lines on the left side of the screen and have also started affecting the left-hand focus of the image shown on the screen. I have had this TV for 14 years and had a projection adjustment done once before.
Thank you in advance for your assistance.
Ed Alexander
Dec 06, 2008 | Toshiba Televison & Video
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Toshiba TP50H15
You can adjust the lines and make them straight. You can also in the same process, make them line up.
1. With the TV on, press the mute button the remote control so that you have picture but no sound.
2. With remote in one hand (holding it as far from the TV as you can but still be able to reach the TV with your other hand), press and hold the mute button again, with the other hand, using the control panel underneath the screen, press the menu button on the TV set.
You will notice an "S" on the screen on the right hand side about 2/3 from the left, halfway up the screen (If you did this right).
This means you are in service mode.
With the remote, curse right only once and you will have some information displayed in the upper left. The top line is Item, the one underneath is Data.
Press "7." This will display the built in cross hatch pattern. You can move the line around with the directional circle located at the center of the remote. Using the "3" button, you can decide which color to move. To move the curser to a new location, The number pad doubles as a direction key pad. (2-up), (4-left), (6-right), (8-down). To simplify the process, you can eliminate the red or blue or green lines and only focus on one color at a time. "0" will shut on/off the green line. "100 button" will shut on/off the red line. "CH RTN or Enter will shut on/off the blue line.
"7" will exit the process as well as get you there.
Power off when you are done and turn back on.
Repeat as needed.
Jul 05, 2008 | Toshiba 50HX81 50" Rear Projection...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Convergence
you have bad convergence ics
Apr 13, 2007 | Toshiba TP61H60 61" Rear Projection...
Toshiba 46HM95 46" HDTV Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
