Question about Sony PlayStation Portable (PSP) Console
Disk put in
Does not recognize andything...no umd on it...doesnt sound like disc is spinning
  • 46 Answers
Clean it!
Posted on Dec 25, 2007
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
Ok my psp umd clicks but i think it is the umd door now when i close my umd door dose not spin if i slam it and put force on the door it will spin til i let it go then the umd disc will stop do i need to...
Yes, I would recommend replacing the door. That sounds to be the main problem. It shouldn't be too hard, in fact I found some instructions for you to use, here.
Good luck,
Brandonmxb
Dec 13, 2009 | Sony PSP (Piano Black)
Dr787t won't play disc. Player won't recognize
You can try to stop this by dis-assembling the unit to gain access to the laser and you can clean the laser using a cotton bud or cue tip, if that doesnt solve the issue, what you can do is with the case off, put in a dvd and see if it spins, and also note if the laser is lighting up, if it isnt lighting up or if the disc isnt spinning you may need to replace the dvd loader of the unit.
If the laser doesnt light up and the disc doesnt spin its possible you may need to replace the MPEG Printed Circuit Board which you will fing attatched to to the dvd loader via small ribbon cables, be carefull when removing these if you need to remove them or a seriens of small plugs. I hope this helps. Good Luck.
Dec 06, 2009 | LG DR787T DVD Recorder
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
My psp won't load umd's and all i hear is a scrathing sound
The UMD laser might be dirty or broken. Open up the UMD drive and give the laser a clean with a lint-free cloth. Then pop the disk back in and try again. If that doesn't work, you will need to get the PSP repaired or buy a replacement laser and do it yourself.
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
Help
Hi Bvogel987,
You probably need a new UMD drive. I have seen this many times. Try the following to restore the drive.
  1. Turn the PSP-1000 on,
  2. Open the UMD door
  3. Press down on the black peg poking up at 8 O-Clock in reference to the disc spindle.
  4. You should see the disc spin, and Laser light up. If either does not, then you need a new drive.
  5. If they do spin and light up, Take a toothpick, and wrap paper towel aorund the tip of the tooth pick,
  6. Dampen the toothpick swab with a Windex type cleaner.
  7. Swab the laser lens, and move the lens with you finger or toothpick to the right a couple of clicks. Place a new paper on the toothpick and dry the lens.
  8. Test. If this did not work, you still need a new Drive.
I run www.PlayStationClinic.com and we replace PSP-1000 UMD drive for $47.00 including return shipping and handling.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Console
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Psp problem
if it doesnt read the disk,you may want to open it up (but voiding the warranty) and clean the UMD drive.
if it doesnt read just one UMD,it might be the disk.
if cleaning the UMD drive doesnt work,you may have to get a new drive,or a new psp.
Jul 25, 2008 | Sony PlayStation Portable (PSP) Console
Psp
Hi Jleew,
You should check to see if another UMD will work first.  Also try them in another PSP.  If your sure your PSP is not reading Discs, then and only then, Clean the Laser lens carefully.  Using a strong flashlight and magnifying glass, look into the UMD drive with the UMD door open and look for debris like hair or lint, and also dirt and dust.  A black switch pokes up on the left inside the UMD drive.  Its a little black stick.  When you press down on this Black stick, your UMD disc motor should spin for  second or two.  The UMD laser lens should light up when your press this switch.  If any of this does not happen, you need to replace the UMD drive. If you need someone to do this which if you have never done it, you need some knowledge big time.
I can do this for you if you're in the USA for $55 including a New UMD drive, REturn Shipping, and 90 day warranty. Contact Repairtech@playstationclinic.com
Oct 23, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
118 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
