Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Problem for Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
THE WATER IS NOT DRAINING AFTER THE WAS CYCLE IS
By bienemyaeb on Oct 10, 2009
THE WATER IS NOT DRAINING AFTER THE WAS CYCLE IS COMPLETE
Best Solution
posted on Oct 10, 2009
Very Helpful)
heresthedeal
Rank: Master
Rating: 93%, 5 votes
there is a drain in the bottom that could be stopped up.
otherwise check for 120vac on the sylinoid on the drain out underneith the unit. sorry not sure where it will be on this model. if there is no voltage it is going to be the controal board in the door.
if it has voltage at the sylinoid that means that the coil on the sylinoid is burnt out.
try looking at the screen on the drain first in the bottom of the unit.
hope this helps you
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
TheMazz
Rank: Guru
Rating: 92%, 42 votes
There is three possibilities so I'll tell you how it works.
First the timer turns and activates the water pump and drain valve (solenoid). If you have a computer controller it does the same function as the mechanical timer.
So, I can't tell you what it is unless you can turn the timer to the place where it drains and you hear the pump running. If so, then the pump and timer are good and the solenoid is bad. If you don't hear the pump come on then the pump or timer is bad.
You would need to know how to use a voltmeter to troubleshoot this problem.
The pump and solenoid are underneath the unit.
If I were to guess, it is the solenoid valve since they fail at a higher rate than the pump (rarely) or the timer (commonly).
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 17482 / 17484 /
Questions and Unsolved Problems for Kenmore 24 in. 17482 / 17484 /
Do you recommend Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher?
Answer
Answer
Top row of dishes arent getting cleaned. Everything else is getting cleaned. What is the problem?... (More)
Answer
the soap is not dispensing properly in the machine. at the end of the wash no matter what cycle it... (More)
Answer
The wash cycle continues for longer then normal and the heating element( on bottom of inside )stays... (More)
Answer
Cycle is disrupted. Many lights f;ashing. I have reset it previously when lightning struck near the... (More)
Answer
The dishes on the top rack do not come clean. The spray holes are clear.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repairmen
in , CA
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
